Audi 80 b4 tdi avant brake carriers
  • sjp001
    • Oct 2014
    • 96
    Hey all, My b4 80 avant (not an s2) is just having the yearly mot challenges haha and I need new brake carriers front and rear. The garage have found some that need to come from Germany which is fine, but I feel bad for them having the car stuck there for weeks. Does anyone know of any in the uk? I can't seem to get the part numbers off 7zap but I wonder if these were used on lots of other cars? Many thanks in advance for any help!
    • Dec 2017
    • 5991
    I don't understand why you need new ones? They are cast and normally clean up well. New boots and stainless pins with fresh grease and they will be like new.
    If you really want new, try brakes international.
    • K Simmonds
      • Dec 2007
      • 7627
      That's how garages make their money, selling customers parts they dont't really need and the wildly inflated labour on top.
      The fronts are super common Girling 54's, the rears vary a bit year to year.
      There's almost certainly nothing serious wrong with the calipers fitted, they just need the pistons popping out ang a good clean.
      Edit.. Just read the first post again, the carriers are pretty much indestructable so why they woud want to change them is beyond me. Just clean them and they'll be fine.
      1990 B3 2.0 80 quattro.
      1992 C4 2.8 Avant quattro
      1994 MTM RS2.
      1998 B5 TDI quattro Sport.
      2000 B5 TQS.
      • 5cylinderman
        • Oct 2011
        • 367
        If you do actually need new carriers, which sounds quite strange to me you can take a look at TRW Aftermarket.
        TRW writes the rules on braking systems; we’ve been designing and making OE disc brake systems for the world’s top vehicle manufacturers for nearly 100 years.
        • sjp001
          • Oct 2014
          • 96
          Thank you so much to both of you, I really appreciate it as I know you are both experts. I'll see if I can take a look at them.
          • sjp001
            • Oct 2014
            • 96
            5cylinderman Many thanks also and that's brilliant. I'll investigate further first.
            • K Simmonds
              • Dec 2007
              • 7627
              No problem, happy to help out.
              I've done countless amounts of brake services and only have had to replace a carrier a couple of times on very old cars where they had corroded past the point of safety.
              1994 MTM RS2.
              2000 B5 TQS.
                I have these surplus to requirements, PM me if they’ll work for you.
                • Jaswan
                  • Apr 2011
                  • 766
                  I'd try and take the car to another garage before shelling out....
                  Jase
                  • sjp001
                    • Oct 2014
                    • 96
                    Many thanks for the help! Newsh thanks very much but it looks to me like those are rear carriers and it seems to be the fronts that are harder to come by. I'm going to speak to the garage later so hopefully will sort something out.
                      • Dec 2017
                      • 5991
                      If you have no luck, I can hopefully overhaul them for you for the cost of parts and postage.
                        Yes they're rear ones
                        • sjp001
                          • Oct 2014
                          • 96
                          Thanks all the same Newsh!
                          Dave that is a legendary offer as always and thanks so much! However there's no way I would take advantage of your generosity and expect you to work for nothing! I'm sure I can sort something out closer to home - at least it's a simple issue.
                            • Dec 2017
                            • 5991
                            No problem. It wouldn't take long. 10 minutes in the blasting cabinet, two coats of HEL caliper paint and oven bake to cure.
