Hey all, My b4 80 avant (not an s2) is just having the yearly mot challenges haha and I need new brake carriers front and rear. The garage have found some that need to come from Germany which is fine, but I feel bad for them having the car stuck there for weeks. Does anyone know of any in the uk? I can't seem to get the part numbers off 7zap but I wonder if these were used on lots of other cars? Many thanks in advance for any help!
Audi 80 b4 tdi avant brake carriers
I don't understand why you need new ones? They are cast and normally clean up well. New boots and stainless pins with fresh grease and they will be like new.
If you really want new, try brakes international.Nothelle S2 Avant
Urs6 plus project gone -
That's how garages make their money, selling customers parts they dont't really need and the wildly inflated labour on top.
The fronts are super common Girling 54's, the rears vary a bit year to year.
There's almost certainly nothing serious wrong with the calipers fitted, they just need the pistons popping out ang a good clean.
Edit.. Just read the first post again, the carriers are pretty much indestructable so why they woud want to change them is beyond me. Just clean them and they'll be fine.Last edited by K Simmonds; 13 October 2023, 18:21.1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.Comment
No problem, happy to help out.
I've done countless amounts of brake services and only have had to replace a carrier a couple of times on very old cars where they had corroded past the point of safety.
1994 MTM RS2.
2000 B5 TQS.Comment
I have these surplus to requirements, PM me if they’ll work for you.
If you have no luck, I can hopefully overhaul them for you for the cost of parts and postage.
Urs6 plus project goneComment
Thanks all the same Newsh!
Dave that is a legendary offer as always and thanks so much! However there's no way I would take advantage of your generosity and expect you to work for nothing! I'm sure I can sort something out closer to home - at least it's a simple issue.Comment
No problem. It wouldn't take long. 10 minutes in the blasting cabinet, two coats of HEL caliper paint and oven bake to cure.Nothelle S2 Avant
