Porsche 996 calipers
  • Dr H
    • 1175
    Cheers Doug
    Can see the wheels but the package deals link isn't working
    Ex 1994 Avant - now driving a Lotus 340r
    • Doug_RS2
      • 3847
      #122
      Doesn't work for me either- best to phone.
      • Pete_RS2
        • 800
        #123
        Not suffering from anyhting but a healthy looking bank account .
        Money to burn
        I've been on a spending spree myself since new year - homefries, HID headlamps, 4 x tyres, heated seat kit, boost gauge, Blaupunkt MP3 head unit/CD changer on the way & now these Porsche brakes.
        You only live once, right ?
        Now RS2'less
        '99 VW Passat VR5 Sport
        • Dr H
          • 1175
          • Dr H
            • 1175
            I've been thinking :wacked: - no jokes please
            Is there an issue with using rear calipers on the front. The ones I am looking at have 2 different size pistons. Which is supposed to lead, the large or small?
            Looking at the calipers Alistair pointed out on ebay
            http://cgi.ebay.co.uk/ws/eBayISAPI.d...EBWA%3AIT&rd=1
            It looks as though the small piston leads (presuming that the fluid crossover tube is on the rear of the caliper). Is this correct or should the large piston lead?
            If the large piston sould lead would it mean swapping calipers left for right and then swapping the fluid crossovers to the other end of the caliper (to keep them at the rear)
            • dan_b
              • Sep 2003
              • 3670
              #126
              AFAIK - the small piston leads. It's something to do with pad gassing. The trailing piston has to act on a pad surface that will have gas under it, so the bigger piston is used to provide a stronger braking effort to get through the gas?
              • dan_b
                • Sep 2003
                • 3670
                #127
                Money to burn
                I've been on a spending spree myself since new year - boost gauge
                Peter - off topic I know, but what boost gauge did you get? How long did it take you to fit it? Where did you locate it?
                • Pete_RS2
                  • 800
                  #128
                  Dan,
                  I've gone for this Smiths one.
                  I ordered it 3 weeks ago from them direct as they're going to fit a black bezel for me but I'm still waiting for it as they're on backorder. I checked with Demon Tweeks & they're out of stock aswell.
                  Now RS2'less
                  • Corey
                    Banned
                    • Sep 2003
                    • 2793
                    The 996 front caliper is trailing on the Porsche, which is exactly the same as the S2 (haven't I already explained this???) the large piston needs to be at the top of the caliper as on the Porsche (so would be classed as trailing the smaller piston). If you are fitting these to a leading design then the large piston will end up on the bottom.
                    If you are using the rear caliper, and there is no real reason why you shouldn't if you are happy with it, I have used rear calipers in some conversions also, just make sure you have the large piston trailing.
                    DO NOT SWAP CALIPERS OVER FROM LEFT TO RIGHT. KEEP THEM ON THEIR ORIGINAL AXLE!!!
                    I have found another place that will strip and paint these calipers as per original spec, all for £75 + VAT and carriage. I have a set with them at the moment and I will comment on there return.
                    Corey
                    01636 822288
                    • Dr H
                      • 1175
                      Corey thanks for the reply - I can be a bit thick sometimes!
                      Here is a pics of rear calipers off a 911 GT3. If I'm right they are fitted in a leading position on the rear of the Porsche.
                      Looking at the picture I'm presuming the top one is LH and the bottom is RH. This means I could fit calipers like these to the S2 keeping them on the same axle would mean the fluid crossovers would be at the top of the caliper as opposed to the bottom on the Porsche.
                      I could swap them round with the bleed nipples so the bleed nipples would be at the top and the crossovers at the bottom - yeah?
                      • Corey
                        Banned
                        • Sep 2003
                        • 2793
                        We can all go a bit Pete Tong at times.
                        For the nipple crossover swap (matron!), lay the calipers in front of you and remove the nipples (ouch!), now remove the left hand crossover pipe and put it where the nipples were on the right hand caliper, now remove the right hand crossover pipe and place it where the nipples were on the left hand caliper. Now replace the nipples where the crossover pipes once lived.
                        HTH's?
                        A word of caution, the crossover pipes are extremely tight and they can round off really easy, sit down when you ask for a price for replacement if you knacker one!
                        The method I use is to apply heat to the aluminium, the different materials expand at different rates and allow the crossover pipes to undo really easy.
                        Oh! and welcome to the world of Monoblock
                        Corey
                        01636 822288
                        • Dr H
                          • 1175
                          Cheers Corey.
                          Not quite in the world of Monoblocks yet but if I get the right deal I will be
                          • Pete_RS2
                            • 800
                            #133
                            After a long wait i've finally got my Porsche monoblocks fitted. I'll be bedding them in for a week so I haven't put them to the test yet. The pedal feels more responsive though & doesn't travel anywhere near as far . I'll see if I can take some better pic's at the weekend.
                            They squeal a bit at the moment when you come to rest. Did anybody else's when they were first fitted ? Anyway here's what it cost:
                            Porsche 996 front calipers (used) - £200 - Design 911
                            bespoke caliper brackets - £80 - martinjs
                            Audi A8 (Brembo) front discs 314x30mm - £58 - GSF
                            machine disc OD to 308mm - £15 - local engineering firm
                            Pagid Fast Road pads - £70 - Design 911
                            Porsche pad dampers - £21 - " "
                            Audi RS2 brake pipes (caliper to strut) - £11 - VAG Parts
                            bracket & caliper mounting bolts - foc - local hardware store
                            Total (inc. VAT) - £455
                            @martinjs You did a great job with those brackets m8
                            Now RS2'less
                            • Pete_RS2
                              • 800
                              #134
                              Now RS2'less
                              • s2driveruk
                                • 12696
                                Looking good.....
                                David
                                1992 3b S2 Coupe
