We know the 996T discs fit but unfortunately due to the offset it means that stock wheels will not fit without spacers. If they were identical to the RS2 discs there would not be an issue. The only way to get back the 10mm (or more) needed is a two piece disc so that the caliper is positioned in a more or less stock position and the rotor is moved back in towards the strut. The difference in the disc offset is basically the clearance afforded by the spacers so in theory one should cancel the other out!
The question really is whether the hat/bell of the 2 piece RS2 can be used on a machined 996T disc to achieve the goal of 330mm disc/GT3 calipers within the stock wheel without spacers.
