Big Brake upgrade??
  • Monkeymagic
    • Mar 2012
    • 3419
    i called camskill. i thought it was a person then realised it was a company. what an idiot. anyway after one guy called Will bought some discs they've sold loads! I've got to call them Tuesday and they.ll order some. all need now is flex i and some quality brake fluid. might make it round the ring yet
    • willg54
      • Jun 2009
      • 2055
      Haha I should be on commission! I've had loads of friends order them now. You'll have them by weds too
      Sent from my GT-I9300 using Tapatalk 2
      1996 Audi S2 - 295bhp and 326lb/ft - Complete Rebuild Project
      1994 Audi 80 - 2.0 8v (slow but reliable!)
      • Big Lee M
        • 2571
        [QUOTE=geryS2;665852]Regarding rear brakes upgrade, what s a bolt on setup upgrade for a S2 avant ??
        i hear it s actually easyer to do one on a S2 avant than an RS2 due to the hanbrake,
        Best rear brake upgrade on a avant is the B6/B7 300mm set up, it's a direct bolt on job and it make a huge difference. I also had that set up on my avant with the Porsche mono blocks and it was really good braked level and stopped on a dime.
        Just some finishing touches to do now
        • geryS2
          • May 2006
          • 814
          • Home: Belgium Current: Portugal
          #34
          [QUOTE=Big Lee M;665976]
          ok, thanks for info, but with which caliper ?(porsche monoblock also at the back ?) and 300MM B6/B7 are from front or rear ?
          any info or thread related ?
          thanks again
          S2 's and oldtimers
          • afterburner
            • Mar 2012
            • 246
            • Country: Bulgaria
            #35
            Can normal B4 front 280x22 mm discs and single pot calipers be used on the back of a sedan/avant? Without the cable handbrake, of course. I have some suspension parts and form what I can see the distance between the mounting bolts of the carriers is the same front/back.
            • irishs2
              • Apr 2009
              • 2455
              I just placed an order for 8 grove on camskill, I couldnt find the product on their site but after contacting them they have these listed
              323mm:
              8 Groove: ÂŁ99.95 http://www.camskill.co.uk/m13b0s744p80173/
              12 Groove: ÂŁ139.95 http://www.camskill.co.uk/m13b0s744p109236/
              16 Groove: ÂŁ149.95 http://www.camskill.co.uk/m13b0s744p109237/
              Eric
              95 S2 Avant under rebuild.
              • snaak
                • 153
                I am looking to swap the original BIG-red calipers on my RS2 for Monoblock's because of the constant maintenance those old Big's need, are the Porsche GT3/996TT calipers a straight bolt on to the brackets and the original 323 discs or should I use the 996 C4's?
                '95 RS2
                  GT3 / 996TT are a lot bigger than your Big Reds, they have a different mouting bolt spacing and they are designed for thicker discs.
                  You want the normal 996 / Boxster S calipers, which should be a straight swap IIRC
                  • snaak
                    • 153
                    So I should use 996.351.425 and 996.351.426. I know these fit on a s2 with s8 discs and rs2 calipers, so they should fit the 323 big red discs of the RS2 without problems? I thought the rs2 discs are too thick for these calipers?
                    '95 RS2
                    • snaak
                      • 153
                      I meant rs2 brackets not calipers
                      '95 RS2
