Porsche Cayenne caliper in Audi S2 obstruct
  • vr6peter
    • Dec 2003
    • 223
    • Country: Austria
    #46
    The brake pads are in the middle of the striking surface.
    • [sTeeWie]
      • Jul 2011
      • 106
      I have obstructed the brake assembly since March, 2013.
      The braking efficiency is perfect.
      In front I drive 360x34mm with Cayenne calipers and behind 330x22mm with S6 calipers.
      You from me can get adaptor for it.
      I will still supply later pictures.
      • jade
        • Jan 2005
        • 1811
        • Home: New Zealand Current: Spain
        #48
        Hi Could you post a better picture of the HR coilover spring, does it use a helper spring ?
        RS 2 580HP
        • europeanme
          • Oct 2005
          • 3817
          Spec's please, and photos of them when they're on the car. Thanks.
          as requested....
          • quattrostyle
            • Oct 2006
            • 6229
            Them calipers look sick on an S2
            • europeanme
              • Oct 2005
              • 3817
              ta for that....
              its a bit of a shame that the wheel hides the calipers....
              • Sonic
                • Jul 2006
                • 5514
                #52
                Originally posted by [sTeeWie]
                [ATTACH]42570[/ATTACH]
                Those wheels look awesome!
                S2Forum.com Administrator
                • sam80quattro
                  • Oct 2006
                  • 1496
                  how much are your adapters [sTeeWie]??
                  • [sTeeWie]
                    • Jul 2011
                    • 106
                    @ jade: You need a better picture of the H & R coilover?
                    @ sam80quattro: A set Adaper costs € 230 plus the shipping to England.
                    • Rocco
                      • Aug 2007
                      • 6393
                      • Country: Spain
                      #55
                      What rotors are the front ones?
                      • [sTeeWie]
                        • Jul 2011
                        • 106
                        I have installed Audi S8 brake discs.
                        360x34mm.
                        • Rocco
                          • Aug 2007
                          • 6393
                          • Country: Spain
                          #57
                          Perforated from factory or are them aftermarket?
                          Do you know It's weight?
                          • [sTeeWie]
                            • Jul 2011
                            • 106
                            I have installed Zimmermann brake discs. The weight can I contact the manufacturer.
                            • Wrath
                              • Jan 2011
                              • 779
                              [sTeeWie] Do you use zl/R18 calipers with zl/r18 brake pads in front?
                              1995 Audi S6 - AAN (~350hp)
                              2008 BMW 530xd (235hp)
                              2011 KTM 990 SMR - custom tuned (120whp)
                              • [sTeeWie]
                                • Jul 2011
                                • 106
                                @ Rocco: The Zimmermann brake discs weigh 13.25 kg.
                                @ Wrath: I have installed ZR18 calipers with ZR18 brake pads.
