K24R 300mm / 314mm budget rear brake upgrade
  • Rusty
    • 18953
    No, as only the prototype set was ever made.
    If there's demand, I can get a batch made when I do the Avant kits.
    • Nero
      • 347
      Ok,
      Would love a set.
      www.S2power.com
      S2 Coupe - decat - EPS exhaust - RS2 IC - RS2 front - RS2 brakes - RS2 mirrors - Koni shocks - H&R springs - Jehnert doorpanels & Audison Amps - leather & sunroof - VEMS - USA rearlights
      • Rusty
        • 18953
        I will have a 314mm set available soon, if that's any good to you?
        • vti2
          • Jul 2010
          • 281
          • Home: Portugal Current: Germany
          #124
          The rear 302 rotors from the Audi A6 4F fir plug&play.
          • Rusty
            • 18953
            They're too thick. 11mm discs are tight enough...
            • vti2
              • Jul 2010
              • 281
              #126
              You need these ones 24.0112-0176.1 412176
              only need to schimm the carriers at the inner side about 0,7mm.
              • Teg
                • Sep 2011
                • 158
                I have 330mm AP Racing brakes up front so think the 314mm kit would work best for me.
                Have you got a 314mm kit available?
                Thanks
                • Rusty
                  • 18953
                  I only ever had the 314s mad, so that's good
                  i'll see if I've got any.
                  • Teg
                    • Sep 2011
                    • 158
                    Thanks
                    What is included in the kit? Is it just the adapters or does it also include the disc?
                    • montyrs2
                      • May 2008
                      • 522
                      Hi mate, any kits left?
                      • Rusty
                        • 18953
                        There's a set that I'm waiting to get back but other than that, I've not got any and I'll need to find a new machinist before I can get another batch made.
                        • Rusty
                          • 18953
                          So, I fitted an early spec (marked 28, not 37) brake pressure regulator and this has evened out the braking a lot with the 314mm front and rear. To run without ABS, I'll need to go fully adjustable, so that's another job but it's a lot more even now. With the ABS off, it's just dragging at the rear, although on track, with heat in the front pads and tyres, this may be different.
                          • Az786
                            • Sep 2014
                            • 218
                            Did you end up getting enough interest for the s2 avant brake kit?
                            • Chris5044
                              • Feb 2005
                              • 1663
                              Hey Rusty Id be interested in the brackets to this upgrade or kit.. for 302mm.. as i have the 996 fronts n seeing that this is a well balanced setup.
                              huge thank you for doing this!
                              • Chris5044
                                • Feb 2005
                                • 1663
                                Hey is Anyone here on the forum got these brackets for sale please?
                                Or have drawings or dimensions of these please?
                                Huge thx in advance. Im looking to get these asap. Xx
