K24R 300mm / 314mm budget rear brake upgrade
  • Rusty
    • 18953
    Looking in to rear brake disc options that retain the OEM rear caliper. Should be a very cheap way to add some extra meat to the rear brakes with minimal fuss and total safety. Watch this space...
  • Rusty
    • 18953
    Discs ordered. £30 the pair They're 15% larger and there's an option that's 20%...
    • Rusty
      • 18953
      Fecking rear caliper bolt hex rounded on me while trying to remove it... will have a fight with it at the weekend. Got some replacements in the cupboard from one of my just in case orders to Vag Parts way back when
      • s2driveruk
        • 12696
        yeah those little hex heads are prone to that...whats the plan then, bean spilling pls
        1992 3b S2 Coupe
        • LHD_Kid
          • May 2006
          • 3697
          Carriers on their way to you... I hope you didn't want me to measure them before they were sent.... coz I forgot....
          Complete with fully working sliders...
          You will need to clean the rust of them though if you want them to look pretty
          Chris
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            Ultimot gmbh sells a small kit to use stock rear caliper with 300x10 rotor
            Andy,do you know the stock rear piston size?
            • andy10v
              • 5996
              Are you going to space the caliper out?
              Irwin do a great tool for those caliper carrier bolts, hammer it on and undo. Has saved me a lot of grief a few times now.
              Sold ABY-stock
              • s2driveruk
                • 12696
                1992 3b S2 Coupe
                • sidrick
                  • Jan 2011
                  • 1342
                  Life/knuckle/sanity savers. Best 'tool' I've ever bought
                  • sidrick
                    • Jan 2011
                    • 1342
                    Chris
                    Rusty, would you mind measuring the dimensions of the slider for me when you receive these? Would be much appreciated
                    • Rusty
                      • 18953
                      Sweet, cheers, I'll look that up.
                      Not measured the rear piston size but will do so. Surely the informatiojn is on here somewhere?
                      I haven't found a 300mm disc that's suitable but have found some in the 275-290mm region, which require minimum modifications to fit. I'm going to try the smaller end of the scale, as there are 2 identical hat discs that are at opposite ends. The idea is that you buy some discs, brackets and maybe a tiny spacer for behind the disc and it's all bolt on with no fuss.
                      I have also found some suitable 12mm discs that I'll be looking in to once I get the carriers off Chris
                      • Rusty
                        • 18953
                        302mm discs are fitted to some A6s but the hat height is all wrong and they're 12mm thick, not 11mm, so I wonder if that's the same disc...
                        • Rusty
                          • 18953
                          Do those Irwin tools work on cap heads? That's what's rounded off...
                          • Rusty
                            • 18953
                            Volvo have a 302mmx11mm rear disc that's fitted to their S60s. The hat height is pretty good but the centre bore and PCD are both wrong.
                            • AndyP
                              • 6049
                              Yes, no toolbox should be without a set
