CoupeQuattro rear brakes bolt-on upgrade version
This is a sticky topic.
  • _ShurikeN
    • Mar 2010
    • 733
    • Country: Russian Federation
    A version for Coupe Quattro typ89 bolt-on rear brakes upgrade with 5x112 lug pattern:
    Rear hubs from A4 B5 Quattro OE VAG p/n 8D0 501 653 B (+8mm track outwards each side)
    Cast iron calipers from UrQuattro/200(44)/V8(D11)/UrS4(4A)/UrS6(4A) for 269mm brakes VAG p/n 447 615 423(4)
    Rear caliper carriers from S8(D2) 280mm VAG p/n 4D0 615 425 C
    Brake discs A4(B5) front == S8(D2) rear 280mm VAG p/n 8E0 615 301 B(P)
    Brake pads, let's say, VAG p/n 1J0 698 451 L
    ~~2-mm-thick M10 washer is to be placed between hub carrier and caliper carrier.
    Caliper carrier bolts must be replaced to smth at last 4mm longer than native ones. The easiest and cheapest way is to use OEM VAG bolts N 101 815 02 (M10x1.25x40) and cut away redundant thread.
    Great
    B5q rear hubs open up a few possibilities actually.
    I have parts here for something similar to use 310x22 Phaeton rear disc
    • _ShurikeN
      • Mar 2010
      • 733
      310 can be installed with these calipers and custom brackets.
      They must be great with something about ~345 brembos on the front.
      • BorisShakhov
        • Feb 2009
        • 224
        For truck not for a street sporty coupe
        345 weighs a ton!
        • varia
          • 821
          • Current: United States
          I have
          Audi B5 A4 rear hub (I had original s2 hubs, but for this setup i need that extra 8mm that the a4 hub has)
          Audi urS4/6 rear calipers
          Audi B5 S4 rear caliper brackets
          Audi B5 S4 rear vented brake disk
          • _ShurikeN
            • Mar 2010
            • 733
            Good version too.
            Inexpensive brake disk 8D0 615 601 D, but caliper carrier 8D0 615 425 was unaffordable under my circumstances.
            • Wolfgang
              • Mar 2006
              • 250
              or just like i did:
              a4 b5 quattro rear hubs
              rs4 b5 caliper-brackets (unmodified)
              girling 41/43 from urs4/urs6
              standard brake line
              standard hand brake cable
              rs4 b5 brake discs
              this is really pnp for 312mm on the S2 coupé and fits perfectly..
              S2 Coupe ABY
              S2 Sedan
              S6 20V Avant
              www.audis2.de
                Your solution is the best Wolfgang, just the cost of the RS4 rotors is pretty crazy!
                • caterpillar
                  • 2480
                  to hav TOO big brakes on its too silly.. spec in the rear end.. i hav 330mm rotor on my s6 car... and this car are a heavy vagon... 18" rims are the smalles one.. and the tyres cost alot...
                  big brakes are a good idee, but not too big...!! its heavy also..
                  • _ShurikeN
                    • Mar 2010
                    • 733
                    Slightly updated some tech info and uploaded better pictures of an assembly.
                    • Oddi78
                      • Mar 2021
                      • 10
                      • Country: Norway
                      Originally posted by Wolfgang
                      or just like i did:
                      standard brake line
                      rs4 b5 brake discs
                      Must the hub be from RS4 og can I use a hub from a 1.8t a4 b5?
                      • Jaswan
                        • Apr 2011
                        • 771
                        I believe that all B5 quattro rear hubs are the same?
                        Jase.
                        • Oddi78
                          • Mar 2021
                          • 10
                          • Country: Norway
                          Hallo!
                          What set up do you recoment in front with this 280mm brake kit in the rear?
                          • _ShurikeN
                            • Mar 2010
                            • 733
                            Hello,
                            I have this setup: https://www.s2forum.com/forum/techni...e-on-the-front
                            I would recommend something similar. Calipers with 4 big pistons (40/44mm), 2 halves (non-monoblocks). Radial-mounted calipers would be smarter of course (Audi RS2, Porsche, Alfa-Romeo etc.) I'm planning to change my calipers to ones from RS2 just because I have found original ones with original brackets (for the sake of authenticity) though RS2 calipers have smaller pistons.
                            Would not recommend Cayenne 17Z/18Z: in my opinion they are too big and heavy for small chassis audis, leave them for big-chassis 44/4A etc.
                            Tandem vacuum booster with 25-27mm main cylinder (I have one from Allroad 4F).
                            Extra vacuum reservoir would be nice to have. Planning to install one from Volvo.
                            • Oddi78
                              • Mar 2021
                              • 10
                              • Country: Norway
                              or just like i did:
                              standard brake line
                              rs4 b5 brake discs
                              What do you use in front, and what master cylinder do you use?
