how to remove hydraulic servo.
  • K Simmonds
    • Dec 2007
    • 7627
    Yep, that's right you only need to undo the the UJ on the inside of the fire wall to remove the whole steering column assembly and pedal box... Has you car got Pro-Con ten? As you'll also need to to detach the cable from the upper column to remove it.
    If you've got other jobs to do under there such as repair the flaps on the heater boxes or repair wiring then I'd pull the dash out to do it, that makes life much easier.
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • Tom_
      • Oct 2007
      • 1301
      • Country: Czech Republic
      No , I havent Proco ten...Yes, i have more jobs to do (add aftermarket ECU on the stock place) and change the laps as there is some **** flying from the heater box.
      So that big joint you mean
      Audi Coupe Quattro 2.3 20V
      • K Simmonds
        • Dec 2007
        • 7627
        I'd take the dash out in that case and do it all in one hit as it's make life much, much easier, no Pro-Con ten helps, one less thing to contend with.
        Yes, that's the joint you need to undo to get the column out the way.
        1994 MTM RS2.
        2000 B5 TQS.
        • Tom_
          • Oct 2007
          • 1301
          Thanks mate, I will remove the dash as there will be more work to do and hope that I will put it together
          • Tom_
            • Oct 2007
            • 1301
            #20
            Update: hydraulic brake servo is removed...The flange holds on 3 studs, not 4. I removed the dashboard and it was much easier to get on that third nut...Now the pedal box is loose as well...only the steering rack is holding it...So I removed one nut no.12 and 2x no 21 nuts...anything else?
            • K Simmonds
              • Dec 2007
              • 7627
              That's odd I'm sure there's four holes for studs in the spare servos I have, I was only looking at one the the other day... Anyway glad to hear you're getting there, pretty sure it's just those nuts you mention to tackle.
              1994 MTM RS2.
              2000 B5 TQS.
              • Tom_
                • Oct 2007
                • 1301
                #22
                I have 3 studs...anyway, its done...but i am quite nervous to remove the steering , to be able to match the right angle
                • K Simmonds
                  • Dec 2007
                  • 7627
                  I wouldn't worry too much about removing the steering UJ, the 13mm head bolt will only go back easily if you have it in the correct position, if you can mark it with a couple of dots of paint.
                  1994 MTM RS2.
                  2000 B5 TQS.
                    • Dec 2017
                    • 5984
                    Just don't move your steering wheel whilst it's apart and like Kit said, mark the joint position before removal.
                    • Tom_
                      • Oct 2007
                      • 1301
                      #25
                      Ok, I will try...thanks for the tips.
