I love my aircon, no sweat
so they don't draw a current beyond the auto checks warning parameters. I was not overly hopeful that it would be enough to prevent the autocheck warning, so I am REALLY hapy to hear you guys say "what Autocheck problem?" that is a HUGE bonus I was not expecting!!
) so its possible you may struggle to fit the upgrade ballast into your old metal ballast bracket if you have an HID kit already and are upgrading to the Extreme's. If this is the case on your upgrade, then I'll have new ballast brackets available to give you FOC within the next 10-14 days. I'm having some made for me that I can send out. Please let me know if you need a pair.
watch this space!!
, I had them manufactured to my spec so both ballasts can be mounted as Steve says on the one side behind the LH headlamp as there isn't any room on the airbox side. We had to up the output of one ballast to drive the longer high voltage lead as current loss is measureable along even a 1.5 metre long lead! that took a little while to perfect to make sure the color output of both bulbs was identical.
). So I've worked out what bits i need to do the job proper. I just need to lengthen a few cables and job's a good'un!
