Where the hell would I find this?!?!? I cannot find the plug at all. Need to wire in a clutch pedal switch into pin 39 of the ABY ecu. I could just solder into the ECU plug end of the loom, but thought I would try and keep it neat.
Coding plug T6d......
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nmTags: None -
What’s the clutch switch for Tom? -
Making fire come out the exhaustsigpic
Audi UR Quattro
Audi B5 RS4 645ps 911nmComment
Will be putting the Sachs race clutch to the test using launch and no lift shiftsigpic
Audi UR Quattro
Crikey!Comment
You should find it near the ECU / barometric pressure sensor, it's 6 pin black.
Looks like this:
What ECU / software are you using with flatshift Tom?
Just FYI, calibrating/setting the clutch switch position is important so using a generic flat-shift or launch strategy will take some fiddling to make it work correctly.
Imola B6 S4 AvantComment
Nothing generic with this! It’s being custom tuned on Saturday I hopesigpic
Audi UR Quattro
Must be behind the little kick panel on the left of the car. It’s not by the ECU. I have to take that off anyway to remove the procon 10 cables and some old alarm wiringsigpic
Audi UR Quattro
Urs6 plus project goneComment
Audi UR Quattro
