Coding plug T6d......
  • audiman
    • 4827
    Where the hell would I find this?!?!? I cannot find the plug at all. Need to wire in a clutch pedal switch into pin 39 of the ABY ecu. I could just solder into the ECU plug end of the loom, but thought I would try and keep it neat.
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    What’s the clutch switch for Tom?
    • audiman
      • 4827
      Making fire come out the exhaust
      Audi UR Quattro
      • audiman
        • 4827
        Will be putting the Sachs race clutch to the test using launch and no lift shift
        Audi UR Quattro
          Crikey!
            You should find it near the ECU / barometric pressure sensor, it's 6 pin black.
            Looks like this:
            What ECU / software are you using with flatshift Tom?
            Just FYI, calibrating/setting the clutch switch position is important so using a generic flat-shift or launch strategy will take some fiddling to make it work correctly.
            • audiman
              • 4827
              Nothing generic with this! It’s being custom tuned on Saturday I hope
              Audi UR Quattro
              • audiman
                • 4827
                Must be behind the little kick panel on the left of the car. It’s not by the ECU. I have to take that off anyway to remove the procon 10 cables and some old alarm wiring
                Audi UR Quattro
                • SteveH
                  • 4460
                  Is Mik using a 12v feed from the clutch switch for flat shift?
                  91 Modded 3B
                  14 A6 Avant Black Edition
                    • Dec 2017
                    • 6006
                    Yes, it is. Everything in bits with me and its there on the left hanging down.
                    • audiman
                      • 4827
                      might be
                      Audi UR Quattro
                      • SteveH
                        • 4460
                        Nice
                        91 Modded 3B
