Trying to double check the wiring to the MTF on the water manifold on an /aby avant.
First - 4 connectors attaching into a 3 pin switch - ?? (new switch)
Next thing is the colour identification of the wires to each connector ?? -After twenty years these are not the brightest on the planet.
Also there is the access - its NOT an easy place to live - loom wires are quite short !! - Think I might need to remove the radiator to get better access.
Any one got any experience of this job.
Martin.
Martin.
, I would have given you this:
coocoo:
