no ignition
yes if you remove the parcel shelf below the drivers side dash you can see the electrical connector to the ignition switch on the barrel - black horseshoe shaped connector with some fat high amp wires going to it
Imola B6 S4 AvantComment
[SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
RS2 VOLCANO BLACK] soon to be broken to bits
just seen this on fleebay
is this what needs changing?Last edited by david; 23 December 2012, 17:56.[SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
does anyone knows how the switch comes off? i've pull the socket out of the switch,but cannot get the switch out of the ignition barrel.is it held by clips or do i have to just pull alittle harder?[SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
nearly knocked me self out doing so.
