no ignition
  • david
    • Oct 2008
    • 1268
    Originally posted by audinut
    sorry to state the obvious but if you have 0 power there must be a feed problem from the battery , how did you test the battery ?
    old fashion way,positive + negetive and bang nearly knocked me self out doing so.
    [SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
    RS2 VOLCANO BLACK] soon to be broken to bits
    • audinut
      • Jul 2009
      • 2195
      Have you got a multimeter?
      NOT a car dealer! just an S2/RS2 enthusiast
        Originally posted by david
        so is the ignition switch located in the barral or around the steering column?
        yes if you remove the parcel shelf below the drivers side dash you can see the electrical connector to the ignition switch on the barrel - black horseshoe shaped connector with some fat high amp wires going to it
        • david
          • Oct 2008
          • 1268
          so barrel does'nt need changing,just switch?
          • audinut
            • Jul 2009
            • 2195
            Surely he shouldnt lose radio power if the ign switch is gone?
            • david
              • Oct 2008
              • 1268
              who needs a multimeter when you got sparks flying everywhere
                Yes, just the electrical switch portion. See my previous post with the DIY pdf.
                • irishs2
                  • Apr 2009
                  • 2455
                  Oh no...
                  Eric
                  95 S2 Avant under rebuild.
                  • david
                    • Oct 2008
                    • 1268
                    thats what i thought
                    • david
                      • Oct 2008
                      • 1268
                      suppose i might be able to get a new switch off fleebay
                      or stealers only
                      • A80Avant
                        • 10873
                        • Country: Greece
                        #26
                        if going after an ignition switch, stay away from the fleebay ones. they are cheap immitations and break down in a few months. pay the extra quid and get the stealer one
                        • david
                          • Oct 2008
                          • 1268
                          just seen this on fleebay
                          is this what needs changing?
                          • david
                            • Oct 2008
                            • 1268
                            thanks mate
                            stealers then
                            • A80Avant
                              • 10873
                              • Country: Greece
                              #29
                              yes that is the one.
                              • david
                                • Oct 2008
                                • 1268
                                does anyone knows how the switch comes off? i've pull the socket out of the switch,but cannot get the switch out of the ignition barrel.is it held by clips or do i have to just pull alittle harder?
