Help With Battery Drain
  • bilko0795
    • Feb 2011
    • 1883
    Thanks for that will wait til w/end. I take it that when you attache the meter as per the diagramme it will show that there is power being taken from somewhere and that when i start pulling fuses the reading will drop when the right fuse is taken out. Or it just shows the condition of the battery.
    • irishs2
      • Apr 2009
      • 2455
      Exactly
      Eric
      95 S2 Avant under rebuild.
      • bilko0795
        • Feb 2011
        • 1883
        Originally posted by irishs2
        Exactly
        I was just wondering as when i did a search last night it was said that you use the NEG cable and no mention of the POSS cable for the test.
        • Pat D
          • Dec 2011
          • 748
          • Country: Australia
          Either side of the source will work, you're effectively just breaking a loop and using the meter as a link. Electrically termed as a series connection.
          A clamp meter would've been much easier for you though.
          ABY S2 stroker (work in progress)
          B5 1.8T quattro
          B4 2.3 (decommissioned)
          • bilko0795
            • Feb 2011
            • 1883
            Didn't know there was such a meter does look easier to use though. Im sure i will sort it on the w/end.
              If your battery is under the back seat then do this test.
              Get in the car, loosen the battery terminal and insert the meter. Pos or Neg doesn't matter it will show the same current.
              Close the door and lock it by pushing the button down.
              The meter should show a current of about 0.05 A (50 mA)
              Wait a minute and you should hear a relay tick and the current will drop to 0.005A (5mA) I don't remember the exact readings from my car but the order of magnitude is correct.
              When mine was doing this it was reading 80mA even after the "tick" I had a wire pinched in the centre console (my computer kept resetting to zero too)
              • bilko0795
                • Feb 2011
                • 1883
                Yes battery under back seat. I will try this on w/end.
                • bilko0795
                  • Feb 2011
                  • 1883
                  when i connect the poss battery terminal to black probe on the meter and the red probe to the poss term on the battery it shows up with these readings in the pics and the readings dropped steadily.The meter is set as per in the pics is this the right set up and am i getting the right reading.
                  • bilko0795
                    • Feb 2011
                    • 1883
                    This is the setting I have it on
                    This is what was first read when I connected the wires
                    • Pat D
                      • Dec 2011
                      • 748
                      #25
                      Pull fuses out one by one until that reading falls close to zero. Then you will know what circuit is causing the drain. 4 amp drain will cause the problem you're describing
                      B5 1.8T quattro
                      • twoqu
                        • Sep 2003
                        • 3103
                        #26
                        Think you might have misunderstood the instructions.
                        You need to remove the battery negative terminal completely. You then connect the multimeter leads between the negative battery pole and the negative terminal. So thats one multimeter lead on the bare battery pole and the other on the negative terminal lead. In series means between!
                        I use a spare battery terminal to do this test as that way you can leave it connected whilst pulling the fuses!
                          4 Amps would be lights on, heater fan, or ignition on, that's a big drain. When the meter is reading 0.00 on the 10 Amp scales switch it to 200m (one click anti clockwise) so you can see the milliamps.
                            I'm thinking your ignition switch is broken inside and not switching off properly..
                            • bilko0795
                              • Feb 2011
                              • 1883
                              what number is the fuse for ingnition? i cant find it on the ECU casing? im sure its the ignition switch as ive been under there alot recently
                              • bilko0795
                                • Feb 2011
                                • 1883
                                Right found the B-----d fuse no 4, 44.9 milli amps and dropping steady. would fuse 4 be ignition or most likely interior lights what's the best way to about finding the culprit.
