Need your help tracking down C4 wiring diagrams for the 4A0862257A, 257C and/or 257H central locking pump. This is the one with no remote and no alarm horn, etc. just key activated central locking with interior lighting control (on when you unlock and off when you lock, no beeping at any point). It only has two input plugs. I need this info to install a RightClick remote/alarm system that I bought back in May.
This afternoon, I *finally* found the time and energy to investigate the non-remote central locking control pump that I have in my 94 UrS4 V8 avant. Turns out that it is a 4A0862257C, a two plug (T6 with 2 wires (power and ground only) and T12 with 11 wires in it) locking and lighting control module. No third T16 plug (related mostly to the alarm system (which this one does not have, not even the horn)). The wiring that I have previously investigated for the T12 connector only had about 7 or 8 wires in it so now I have to figure out what the other 3 or 4 wires mean (they might be ones that are in the T16 plug in the three plug central locking pumps). Previous thread: http://forums.quattroworld.com/s4s6/msgs/284009.phtml
Joy. Electrical challenges are *always* fun.
By the way, the 257C was replaced by the 257A at some point. 257A went to 257E at the end of May 1997. But then I am told 257E was dropped in favour of 257H on, get this, end of May, 1995. Two years earlier (ouch my brain hurts). 257H was replaced by a "257P" on April 1, 2005 along with a a 4A0971014 adapter harness. Unfortunately, I can't find the application for the 257P to figure out where this "257A" branch really started.
Owwwwww......
Now to find 257C/257A/257H wiring diagram(s). (all I want is to confirm which wires I need to use for the RightClick remote)
Don't make me beg. (But I will, as needed).
Dave F.
Owwwwww......
Dave F.
