~delta, I Salute You
  • charlie
    • 447
    THANKS TO ~DELTA, MY CAR STARTED FOR THE FIRST TIME TODAY
    AFTER ENGINE REBUILD
    I thought i would start a new thread coz i'm overwhelmed and also
    would like to say a BIG THANK YOU TO DELTA.
    I had replaced all senders on my car but she still wouldn't fire up.
    It kept coming up with the same fault code
    "00514 CRANKSHAFT SENSOR G4 NO SIGNAL"
    THIS IS STRANGE AS IT,S AN INTERMITENT CODE.
    it only shows up every other interogation after codes have been cleared
    so i done the timing again as he suggested :mischeif:
    Timing was correct but off
    done a compression test on all zyl.
    And now for the highlight
    " PUSH START THE CAR "
    You do the maths, i do the Vodka
    RS2 MTM
  • charlie
    • 447
    ENGINE WILL START IF PUSH STARTED BUT NOT WITH IGNITION.
    ANYONE COME ACROSS THIS BEFORE.
    RS2 MTM
      Try a new or different ignition switch?
      • charlie
        • 447
        My ignition has been abit tricky of lately. needs abit of a wiggle to
        get it started
        RS2 MTM
        • WabTheKing
          • May 2004
          • 2567
          i had this
          bad compression
          • rotoryboy
            • May 2004
            • 3281
            get it started
            Charlie, this started with mine then the back of the lock that sits in the plastic module snapped off then it wouldn't start at all. Not the easiest job either
            Mark
            Race Clio RS197
            S2 Coupe ABY (Green) - RIP
            S2 Coupe ABY (Blue) - Sold
            • charlie
              • 447
              Originally posted by WabTheKing
              i had this
              bad compression
              Engine rebuilt compresion OK but ring need time to run in.
              RS2 MTM
              • charlie
                • 447
                Got one from main stealer. £20+vat Ity needs changing anyway.
                Due tom the X-circuit on VW & Audi faulty switch can throw up
                certain fault codes. PM me if you need specific details.
                RS2 MTM
                • rotoryboy
                  • May 2004
                  • 3281
                  I mean the metal bit, not the plastic
                  see here: http://www.s2forum.com/forum/showthread.php?t=11403
                  Mark
                  Race Clio RS197
                  • charlie
                    • 447
                    I'M F$$KING PISSED OFF.
                    Replaced ignition switch with new from main stealer but
                    still no joy. It turn's over but no firing.
                    Tommorow i will;-
                    1) remove earth straps, clean and re-connect
                    2) buy contact cleaner & clean G4 terminals
                    PS: i twice heard aclicking sound from MAF..
                    Is their anything i'm missing
                    RS2 MTM
                    • Jonas_R
                      • 3780
                      • Country: Denmark
                      How about the dizzy? Broke on mine and car couldnot start.
                      /jonas r.
                      Sleeper S2 Avant +450
                      A6 Avant 2.7t Stage 3
                      Audi S2 Coupe RS2'ed
                      • 4WheelDrifter
                        • Oct 2004
                        • 5773
                        • Country: Devon
                        Dizzy?!
                        The clicking could just be the MAF burn off. Clicky
                        SS
                        • Jonas_R
                          • 3780
                          • Country: Denmark
                          Did not read the other thread, but if the car cant start it could be the distributor that has broken?
                          /Jonas R.
                          • charlie
                            • 447
                            /jonas r.
                            No dizzy in this baby, it's an ADU (RS2)
                            RS2 MTM
                            • charlie
                              • 447
                              Originally posted by 4WheelDrifter
                              Dizzy?!
                              MAF wire still intact. done it on two different occassions
                              was like 10 really fast clicks; like an alarm clock
                              But MAF would not stop it from starting.
                              RS2 MTM
