Engine not starting after cam job
  • nothelle300
    • Dec 2005
    • 201
    hi bo i changed mine just by taking the fuel rail out then you can get in by the dizzy to take the locking bolt out.It is a bit of a fiddle,but possible with the im left on.Hope this helps.
    dean
    nothelle n300,alcon brakes,sachs suspension kit,lots still to be done!
    • s2_bo
      • Oct 2005
      • 6067
      #32
      thanks dean. thats a big help ..
      91 S2 coupé - RIP
      98 S8 - Luxury barge
      • s2_bo
        • Oct 2005
        • 6067
        #33
        ecu codes
        ok, I just checked for spark by pulling out lead and plugging in a spar spark plug.
        Cranked engine but no spark. Does the plug need to be grounded when you check for a spark?
        I then puled the error coeds.
        First Code was 4444 this ran through a few times.
        I then Switched off ignition and back on to double check.
        The Next code was 2113 2113 2113etc etc....
        2113 (Blink Fault Code), VAG1551/2 Fault Code Number 00515 Hall sensor in distributor (3B, early AAN engines) or camshaft position Hall Effect sensor on later AAN (S4/S6 engine). Distributor alignment, faulty sender, Mis-located sensor & distributor, Cam timing possibly incorrect on AAN engine
        I then tryed to start engine and much to my suprize it almost started. .
        I reset the ecu to clear the codes and take them again before starting the engine.
        The Next code was 2111 2111 etc...
        2111 (Blink Fault Code), VAG1551/2 Fault Code Number 00513 RPM sensor Open or short circuit, Defective sensor & cables, metal fragments on flywheel teeth
        So not the best of news.
        Im still going to take the front of to check the cam alignment. as i still don't believe that the gear or sensor would brake at the exact time that the belt is changed
        Cheers guys..
        Enjoy the weekend .
        Bo
        91 S2 coupé - RIP
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          #34
          Yes. The spark plug needs to be grounded to spark.
          Code 2111 is pretty normal. G28 doesn't function if the car isn't running. It doesn't necessarily mean there is a fault with it.
          All the evidence seems to be pointing to the Hall Sender.
          SS
          • s2_bo
            • Oct 2005
            • 6067
            #35
            Thanks Stu.
            Will try it again now.
            91 S2 coupé - RIP
            • Jas11n
              • 5067
              Yes, the plug needs placing next to a steel/alloy part of the engine as you crank it over (obviously not a paint surface or a visible piece of alloy)
              The metal lifting eye just behind the camcover is as good a place as any.
              2001 Avus Silver B5 RS4.
              1995 S2 Coupe - sold (sniff)
              • Jas11n
                • 5067
                Too late Stu's there already
                • 4WheelDrifter
                  • Oct 2004
                  • 5773
                  • Country: Devon
                  #38
                  You’re a little more descriptive though Jas.
                  SS
                  • s2_bo
                    • Oct 2005
                    • 6067
                    #39
                    No, No spark.... .
                    Just went to stealer and they checked on ETKA apparently the hall sensor from a 3B is not available individually??
                    Is this true.
                    The best he could offer me was the whole dissy for around £140 (exchange)..
                    cheers
                    Bo
                    91 S2 coupé - RIP
                    • 4WheelDrifter
                      • Oct 2004
                      • 5773
                      • Country: Devon
                      #40
                      Yeah. That's right I'm affraid. Hall sender isn't available on its own for the 3B.
                      SS
                      • nothelle300
                        • Dec 2005
                        • 201
                        try www.probedistributors.co.uk they do a kit to rebuild your dizzy with (rotor/hall sender/cap)For about £40 ish!
                        dean
                        • s2_bo
                          • Oct 2005
                          • 6067
                          #42
                          Please mark lineup!
                          Hi Guys.
                          Turns out belt was very slack. and not lined up at all..
                          The image below has the cam wheel lined up spot on and the crank is way out.
                          Please mark what it should be lined up to on the engine body as all the markings have gone...
                          Need this asap as car is in peaces in public car park .
                          cheers lads.
                          bo
                          91 S2 coupé - RIP
                          • s2_bo
                            • Oct 2005
                            • 6067
                            #43
                            IMG_6459.jpgnother one... slightly out of focus
                            91 S2 coupé - RIP
                            • s2_bo
                              • Oct 2005
                              • 6067
                              #44
                              any one plz?????
                              91 S2 coupé - RIP
                              • S2 Ant
                                • 3682
                                There should be a dimple on the cover behind te pulley.
                                Ant
                                2011 Kawasaki Z1000
