Originally posted by Audi Parts Guru
Wanna switch from K26/27 to GT3071.......
Going by what has been said on the turbo's to date the 30 is a bit more laggy due to the larger turbine but this allows it to sustain higher boost further up the rev range.Originally posted by kalsketCorey, how much is there differrence in reaction between 2871 and 3071 ?
Compare the 2 here
http://www.034motorsport.com/product...roducts_id=321
http://www.034motorsport.com/product...roducts_id=196
I chose the GT3071 as I am not bothered by the extra lag as it is being fitted to a 10v WR which has similar lag characteristics.Corey
01636 822288Comment
I have been thinking about the 2871 also but im afraid it might be too small. But i rather want low end grunt then neckbreaking top end power. Since its my daily driver i want low end power.Originally posted by CoreyGoing by what has been said on the turbo's to date the 30 is a bit more laggy due to the larger turbine but this allows it to sustain higher boost further up the rev range.
Compare the 2 here
I chose the GT3071 as I am not bothered by the extra lag as it is being fitted to a 10v WR which has similar lag characteristics.2003 VW Passat Highline 130 TDI wagon with ALL options.Comment
And the hot side, 30 on the left 28 on the rightAttached FilesCorey
01636 822288Comment
PLEASE can you hide that turbo-porn from my eyes?
Would be a better comparison if the turbo's were both int he same orientation - but, if you look closely, the housing's are the same size, one has just been machined out for the bigger wheel. Damn, they look good... must hold out for the RS2 unit...
I have GTs on both my 10v and RS2. The RS2 sometimes smokes under power when the oil is cold (and the oil pressure is high) so I guess this might be the reason? What was the 'hard way' that you found out about them?Originally posted by CoreyOne word of advice to anybody wanting to use the GT series of turbos make sure you use/order an oil restrictor
http://www.034motorsport.com/product...products_id=74
Don't find out the hard way.*1986 ur quattro,2.5 stroker
*1995 Nogaro Blue RS2,Md357
*1991 RR 20v quattro
*2000 Nogaro Blue RS4,RS6 turbos,tubulars,custom 3" downpipes,Miltek,FMIC,big injectors,RS6 big brakes,RNS-E satnav/TV,592bhp/600lbsComment
Ok guys here's Gt3071 vs K24. turbine side, yes you can spin the 3071 with a huff of air from you your mouth. My reconditioned K24 didnt respond so well, i went red in the face
tryin to spin that shaft.
S2 Coupe fully built.
10.9 1/4mile 0-100 in 3.5secs
Precision 6262 turbo
The Green MonsterComment
compressor side.
My S2 is my weekend ride thus the 3071.
2871 more suited for everyday use.
Thers lots potential in that 2871 just look at kalskets project.Attached Files
