Idle switch???? seems unrelated to me, although it would be worth it to clean it with some carb cleaner...
Martin, did jou check the little ventil that regulates the wastegate and that is behind the right (right side) headlight and it is a size of a matchbox? Mine had a similar problem a while ago. Just spraying inside that ventil with a temperature rsistant grease solved it. I dont know the precise name of that gizmo but it is small and black wit one side covered with a metal plate and has three inlets.
suppose it wont hurt giving it a cleanWe process personal data about users of our site, through the use of cookies and other technologies, to deliver our services, personalize advertising, and to analyze site activity. We may share certain information about our users with our advertising and analytics partners. For additional details, refer to our Privacy Policy.
