Holsets
  • maRS2
    • Oct 2003
    • 366
    • Home: France Current: Thailand
    #31
    this is the very smart project of diesel des:
    Ok no pictures yet, but its underway. I had the maf go through the vnt 20 killing the compressor balance and recking the turbo. So now I'm putting two turbos on to replace it. One is a VNT and the other is a holset. I'm not saying exact models of each, yet. I will run 35 psi at 75% comp...
    RS2 chip by mihnea,PKM short IM, forge dump valve, 3" custom stainless exhaust, 18"X8" Porsche 996 rims, conti contact 245/35 Front 225/40 Rear, QR sport top mount, Powerflex bushes, aloy sub frame bushes, neuspeed 19mm RARB,Hard tranny mount, V8 torsen on RS2
    • Billman
      • 4129
      #32
      Nice Des.
      Go Holset or Go RS4
      • maRS2
        • Oct 2003
        • 366
        #33
        Diesel des: Do you think it could be possible to build the same setup as on your TDI on a ADU with a new vnt borg&wagner from new porsche turbo and one of those big Holset.
        this to get very early spool up and high HP top end with very flat torque curve.
        would a very nice fast road car?
        Sorry to hijack this thread.
        Fabien
        • maRS2
          • Oct 2003
          • 366
          #34
          I think it's called :COMPOUNDED TWIN TURBOS
          lot of the US guy use this on their big diesel truck:
          • diesel des
            • 3896
            #35
            I havnt worked the numbers for compound on a petrol car. Compound turbos are best for engines that nrun high boost eg 2.5-4 bar gauge. I dont think a street audi 20v would live long at those boosts. I would need the maps for the new fancy porcshe VNT turbo. Would love to see those.
            2 turbos setup sequential is better on a petrol car, but again lots of pipeing and changeover valves etc.
            Compound is realitivly easy on a diesel....
            • Billman
              • 4129
              #36
              What kind of gaskets should i use with the Holset? Should i try to find them in the Truck manufacturers or should i make them on my own. If so how should i make them and out of what material?
              Go Holset or Go RS4
              • Tom_
                • Oct 2007
                • 1301
                • Country: Czech Republic
                #37
                Does someone know a p/n of hx40super with 16cm housing? I only find some HX40 with a lot of variations...Or HX40S is custom build turbo? Seems everyone who sells him, have the exactly same prices, no matter what country..I am curious if i can find a seller here in my country..
                This gallery has 1 photos.
                Audi Coupe Quattro 2.3 20V
