Who said anything about a decimal point! :mischeif:
Alternatives to OE Hall Senders/Cam Sensors
This is a sticky topic.
Originally posted by MihneaDavey, there's something wrong with your G40 description, it is not only used during startup!!!
Try to drive your car on full boost after starting it up and disconnecting the G40 and then tell me how it drives after you hit 4600 RPM, mmkay?
Cheers,
Mihnea
I will revise my understanding of the G40.
And PS, I don't need the "Davey". He's the guy with Gumby and Pokey.
Dave F.RS2'd 93 UrS4 5 spd sedan
Have you got the contact details for this company so we can put a post details for people.
thanks
Originally posted by UrS4boyYou never said what the code was. On a AAN the cam position sensor (CPS) (which is only used by the ECU during start up to provide a signal that the engine is turning over and so the the ECU can safely fire the FP relay), the fault code is 2113.
Not that you want to hear this now but two things:
1. You do not (at least on an UrS4) have to take the entire front end off to do the CPS. You do need to take enough off so you can get the cam sprocket off (with the cam belt zap-strapped to it so nothing moves). On a S2, there may not be enough clearance to do this trick.
2. I posted here recently that you (the entire S2 community) can buy just the hall sender portion for less than 10 pounds from a firm in New York city. I did a group buy for my Vancouver BC Canada club and bought 10. With shipping included they were CDN$12.13 each (about 5 pounds). I suggested somebody on the S2 forum should do a GB but nobody took it up and the thread died. It should be in the engine forum.
Hope this instigates a GB because the stealership prices are stupid.
Dave F.Greg
Originally posted by Greg_SHave you got the contact details for this company so we can put a post details for people.
thanks
Luciano Oliveira
BB Automacao - New York Office
http://www.bbautomacao.com
nyc@bbautomacao.com
Hope this helps somebody.
Guys, I can get the Bosch one for around £70. It is on my account so I havent recieved an exact price yet, but it is a good deal cheaper than Audi
Originally posted by ericd View PostGot a price today from Bosch dealer for 0 232 101 020 £73, Audi dealer for 034 905 161 £125
Couldn't get gsf website to give ma a price on a bosch p/no
http://www.bbautomacao.com/Hall-HME-GTS.htm
Makes that Bosch/Audi bracket look REAL expensive.RS2'd 93 UrS4 5 spd sedan
Oh, alright, i'll have two at that price, for the modded 7a head...Carlos.
Can someone of the metalwork gurus on here knock up a bracket that works with this sensor from BB Automacau so that it can make a more suitable drop-in replacement part - as opposed to drilling out original rivets on the factory item and general fiddling about.
Have many AAN users actually used that CDN$5 part with success already ?
PaulPaul Nugent
