Hi!
I though it might be interesting to share some photos of the disassembly of an RS2 turbo. I have tried to keep the procedure in order so that each picture reveals a little more of the components that are hidden away.
I have skipped the compressor housing removal.
Primarily I wanted to see what if anything was different on the RS compared to its more mundane sister the K26. I have noticed differences. I'll discuss what I find later on.
First bit of information. Yes indeed, the RS2 shaft has a l/h thread, that is to say you remove the nut clockwise not anticlockwise.
Secondly, there is only one seal at the compressor end.
Thirdly, it does not have what I would call a 360 degree thrust bearing. Looks like a regular 270 degree to me.
The following pictures should give you an idea of how an RS2 turbo in particular and turbos in general are constructed. This picture shows the turbo with the compressor housing removed.
