Thanks!
Just trying to put something back in!
The comp housing has a 95 date. There seems to be two versions of RS2 the 5324 970 7200 and the 5324 988 7200, although I'm not sure what the difference is!
Hopefully I should have all the bits shortly to attempt reassembly including a 360 degree thrust. It won't be a NASA style rebuild. If it lasts longer than the AET hybrid(not long enough to get any carbon on the wheel) I'll be happy!
I will use what I consider to be the best bits from both.
