according to kruemmer 3b and aan
ex open before bdc ut 42degrees
ex close before tdc ot 9 degrees
7a
ex open before bdc ut 42 degrees
adu
ex open before ut 24 degrees
ex close ot after 1 degree
these are the figures .
Don't forget that the cam swap is only makes the best result, if it is timed well. A cam which designed to run in a n/a engine (like 7Aor NM) may not work better if it is in wrong position. For ex:
if u have restricted exh like small turbine, stock exh mani etc u may need longer duration and,or bigger lift to get rid of the exh gas. But if u have too big overlap too the boost pressure forces out the exh gas and also some air so u lose charge.
So my oppinion is for near stock appl. u should use NM intake & 7A exh, timed like they have no or just a few tenth mm overlap. this combo i've never tired, hard to find NM cams. I;ve tired 7A exh with aan intake it works really fine.
Not always true Jamo mate,
I have a set of cast wishbones here that were from a batch produced with a wrong part number on them.
Part number cast into it says the wishbone is a four stud hub.
Go figure.
Jas
2001 Avus Silver B5 RS4.
1995 S2 Coupe - sold (sniff)
I've used 7A x 2 on my 2.5 with no problem. Large turbo (T66 wit Q-trim) so not much boost until ~4K, but OK at low revs too. Had 170nm @wheels already at 17-1800 rpm Idle was like stock.
Actually I can't argue on this because I haven't driven 7Ax2 exuipped car. My friend just installed it on his S4 and the car idles horribly. I don't know whether it's cause of 7A cams, bad cam aligment (he has both of them made adjustable) or just a lack of untuned ECU (Megasquirt)
I think that You can put them on - drive the car - If You don't like it much - leave the 7A exhaust cam only + 3B/AAN/ABY inlet.
I had bad experience with advancing the NM cams with just pulling the cam pulley 1 tooth back. The car with rs2 setup had a terrible lag before 3500rpm, after that - fantastic journey through the rev range.
I placed them in original place and the lag in daily driving around the city with GT3071R can be comparable to K24 system.
How much advance does moving the cam pulley 1 tooth do to the cams?
Unrelated did your friend get it to idle on the 7A cams out of interest?
