Timucin,
I've been thinking about your problem a lot, you seem to have done all the right things
, the shaving foam is a new one, Gabor is right, patent that one
Assuming that you have no leaks at all - anywhere - then it must be related to the electical management of boost, or your turbos suddenly fooked (doubtful), I think I read somewhere that you have no fault codes showing and that you have a new WGFV (N75) ?
It does sound a lot like 'safe mode', have you tried pulling the fuses to the ECU to clear it and see what happens, if it clears, even if only temorarily?
Sorry its not much but its all I can think of at the moment
Shame your so far away.
Good Luck,
Mark.
P.S. Does your WGFV click if you listen at idle, is there another MAF available that you can use as an alternative (maybe it was damaged in some way when you cleaned it).
Clutching at straws now
.Assuming that you have no leaks at all - anywhere - then it must be related to the electical management of boost, or your turbos suddenly fooked (doubtful), I think I read somewhere that you have no fault codes showing and that you have a new WGFV (N75) ?
.Shame your so far away.
Good Luck,
Mark.
Had it tested for leaks- none, changed the WGFV- it was fine, checked the o-ring -OK. It was finally fixed when a replacement MAF and dump valve where changed. It was not driven though after one was put on so do not know if it was the DV or MAF or indeed both!!! Fixed the problem though
( Thanks Vagsport
