my car is not running as it should
turbo drops to 6 psi at 5000rpm.normally 14 psi.it happened
suddenly.there is no problem until 5000 rpm .
-no fault code
-changed n75
-changed bypass valve under n75
-all hoses checked three times!
-thought may be my nos-sprey damaged the intercooler,removed and sent
it to crack test.nothing wrong
-wastegate checked ok
what can it be?
desperately need help
-no fault code
-changed n75
what can it be?
