7a won't start, not injecting
  • 22alistair22
    • Mar 2016
    • 9
    I've just fully rebuilt my engine and got it fitted and wired up but she's failing to start, after checking the basics of timing and spark I've narrowed it down to fuel, I've got fuel to the rail but after cranking over and pulling a plug the plugs are bone dry, whist I was rebuilding it I fitted a set of bosch injectors and a bypass loom I got second hand. My next step if to take them out and replace them with the originals that it ran on before the rebuild so I was wondering if anyone knew of any further checks to make if that doesn't work as the Haynes manual isn't much more help on the 7a engine.
    Any help is appreciated
    Many thanks Alistair
  • hermanio
    • Jan 2009
    • 800
    had this sort of problem with a rs2 couple off years back, had fuel at the rail and could not find why the plugs were dry. all 5 injectors were stuck..
    5 Cylinder Freak
    • 22alistair22
      • Mar 2016
      • 9
      https://www.s2forum.com/forum/techni...s2-non-starter
      Thank you for that, I'll give them a tap and see if they are free, I've had them for about a year and haven't used them and don't know how long ago they was used before I got them.
      Many thanks
      • John.
        • 2615
        Whilst I've not had this problem on my 7A, I would say.....
        If pressure is good at the fuel rail, you'll need battery voltage to the injectors......check with ignition on and whilst cranking......it'll drop a bit when cranking but if the battery is good expect 10v at least.
        The other wire to injectors is a switched earth via ECU.....can be checked with a noid light, multimeter(set on dwell) or LED test light.
        Or maybe as above the injectors are stuck?.......could be an easy fix!
        • 22alistair22
          • Mar 2016
          • 9
          I've just been to maplin this afternoon and got the resistor and led to make up a diode tester to give that a go tomorrow I found a 7a injection system diognostic pdf file I'm going to work through, hopefully it's a simple fix, Im dying to hear her running again!
          • Bowie69
            • Nov 2013
            • 2675
            Very pleased to hear of someone taking the time and effort to fix one of these engines up, they are getting very rare nowadays!
            • 22alistair22
              • Mar 2016
              • 9
              This is the only picture I have of the engine when I had just got it bolted up to the gearbox. I toyed with the idea of dropping in an s2 lump but I wanted to keep it original, finding obscure parts has been a nightmare!
              This gallery has 1 photos.
              • Bowie69
                • Nov 2013
                • 2675
                Lovely, looks really tidy
                What obscure parts were you after?
                • 22alistair22
                  • Mar 2016
                  • 9
                  Cheers mate, it's been a Labour of love!
                  Just odds and sods really, like the steel heater pipe that runs down the side of the engine from the thermostat housing, I found one in Germany and got it shipped. All the hoses on it was shot aswell and found it hard to find some so went to Roose motorsport as they're only 5 minutes from my house and spoke to them and they matched up most of the hoses to the set they make for the 3b s2 and tweeted to tooling for me. The top hose tooling they used for me was from a Morgan that matched almost perfect!
                  • John.
                    • 2615
                    Originally posted by 22alistair22
                    This is the only picture I have of the engine ......
                    Looking super smart !!
                      • 4754
                      Liking the look of that shiny new 7A there and i'm sure it's something trivial and it will all be up and running very soon!
                        Looks good! Hope it’s running soon
                        • Nuvo
                          • Nov 2003
                          • 3825
                          Any pics of the car to share?
                          • quattro-nick
                            • Sep 2012
                            • 1746
                            • Country: Belgium
                            maybe you have swapped the fuellines?
                            TWINCHARGED power,zero lag
                            AEM W/M injection
                            • 22alistair22
                              • Mar 2016
                              • 9
                              Its really bad that that's all the best photos I've got after owning the car 2 years and she's been off the read nearly all off it, she's had the brakes and driveline rebuilt in the first 4 months then as I was bedding the brakes in the front pulley came loose due to when last Cambelt had done when the previous owner had it and wasn't torqued properly I suspect and it's been off the road since, I haven't even had a tank of petrol through her since owning it
                              This gallery has 5 photos.
