7a won't start, not injecting
  • 22alistair22
    • Mar 2016
    • 9
    Originally posted by quattro-nick
    maybe you have swapped the fuellines?
    I feared I may have got them on wrong but there the original ones and can only go on one way as the supply and return fittings are different sizes on the bulkhead
    Alistair
    • Mikes2
      • 1704
      That's a later car but has the tubular manifold on it. You should be able to pull fault codes from the ecu. The ecu won't run the injectors if something is wrong
      Mike
      http://www.s2-audi.co.uk
      • Bowie69
        • Nov 2013
        • 2675
        Whereabouts are you?
        Nice job on the exhaust wrap I must say!
        • 22alistair22
          • Mar 2016
          • 9
          I'm in Lincoln mate
          And thanks it must have been the most pain in the bum things to do but so worth it! 150ft of wrap went into it!
          This gallery has 1 photos.
          • Bowie69
            • Nov 2013
            • 2675
            A thing of beauty
              True
              • John.
                • 2615
                Originally posted by 22alistair22
                I'm in Lincoln mate
                Liking that
                • hermanio
                  • Jan 2009
                  • 800
                  i assume the 7a already supports a injector output test with vagcom or jumper cable, you can try that
                  5 Cylinder Freak
                  • Bowie69
                    • Nov 2013
                    • 2675
                    I think it does.
                    I know you say you've done the timing, maybe worth re-checking?
                    I'm not sure how this ECU works in the case of dizzy timing being out -it may still spark but may not fire injectors.
                    • steve briance
                      • Aug 2014
                      • 1455
                      it is possible to get the timing 180 deg out...
                      I've been here and done that when changing a distributor. All looked right at first time of checking but on turning it over with the crank bolt, it was clear something was out as after one full revolution it didnt line up anymore. The cam runs at half the crank speed so that is why after one full turn it can be 180 degree out, it needs another full turn to catch up.
                      Triple check all the marks:
                      Look through window in gearbox housing - there is a line and an '0' which should line up with or at least be half obscured by the gearbox window.
                      Notch in damper pulley lining up with mark on timing belt back plate.
                      Notch in camshaft pulley lining up with mark in cam cover
                      2 round marks on back of cam sprockets facing each other AND level with the top face of the cylinder head.
                      Distributor arm pointing at mark / small line in distributor body.
