7a won't start, not injecting
it is possible to get the timing 180 deg out...
I've been here and done that when changing a distributor. All looked right at first time of checking but on turning it over with the crank bolt, it was clear something was out as after one full revolution it didnt line up anymore. The cam runs at half the crank speed so that is why after one full turn it can be 180 degree out, it needs another full turn to catch up.
Triple check all the marks:
Look through window in gearbox housing - there is a line and an '0' which should line up with or at least be half obscured by the gearbox window.
Notch in damper pulley lining up with mark on timing belt back plate.
Notch in camshaft pulley lining up with mark in cam cover
2 round marks on back of cam sprockets facing each other AND level with the top face of the cylinder head.
Distributor arm pointing at mark / small line in distributor body.Comment
