Got myself a full version of Vag-com ( reckoned i'll be need it - allot!
Pulled more codes from the car and up popped these babies:
00-00 - - 00561 - Mixture Adaptation 13-00 - Adaptation Limit (Mul) Not Reached
00537 - Lambda (Oxygen Sensor) Regulation 08-10 - Control Limit Surpassed - Intermittent
00519 - Intake Manifold Pressure Sensor (G71) 07-10 - Signal too Low - Intermittent Readiness
Anybody point me in the right direction? Is the G70 the MAF?
Taken from s2central.net
00561 2413 Mixture Adjustment
- Adaptation limit (mul) exceeded
- Adaptation limit (mul) not reached
Adaptation limit (add) exceeded
- Adaptation limit (add) not reached
Fuel pressure too low
Ignition system faulty
Leakage in exhaust system before catalyst
Incorrect signal from G70
Increased fuel consumption
Sooty exhaust
Check fuel system & pressure
Check exhaust system for leakage
Check G70
00537 2341 Lambda sensor control
- Maximum control limit exceeded
- Minimum control limit exceeded
Low fuel pressure (<3.3 bar)
Intake air leak after G70
Leak in exhaust prior to catalyst
G39 faulty
Fuel pressure too high (> 4 bar)
CO before catalyst less than 0.5%
High fuel consumption
Rich exhaust
Fouled spark plugs
CO before catalyst greater than 3%
Check fuel pressure
Repair air leak
Check G39
Check fuel pressure
00519 2222 Manifold Absolute Pressure Sensor, G71
- Signal too low
- Signal too high
- Control difference
Vacuum line between inlet manifold and J220 pinched, plugged or constricted/bent
Fluid separator in tube from inlet manifold to J220 full of water
Wastegate faulty
Wastegate frequency valve faulty
MAP sensor in J220 faulty
Turbocharger faulty
Loss of power
Check vacuum tube and fluid separator
Check wastegate and frequency valve
Check turbocharger
)Pulled more codes from the car and up popped these babies:
Sooty exhaust
Check G70
G39 faulty
Rich exhaust
Fouled spark plugs
Check fuel pressure
Repair air leak
Check G39
Check fuel pressure
- Signal too low
- Signal too high
Wastegate faulty
Turbocharger faulty
Loss of power
Check turbocharger
), Over the last 5 years, I've always logged 3 errors
