Garrett GTX3071R -Any photos available ?
  • Garrett GTX3071R -Any photos available ?
    Hi .Just wondering if anyone has got photos to share of S2 engine bay with Garrett GTX3071r Gen2 bolted on to K24 flange manifold?
    Mine is a GT3071 on a Wagner RS2 Evo manifold.
    I believe the GTX is the same size but a more up to date compressor wheel design.
    It clears the chassis but you have to cut the leg off the airbox if you want to use a standard one.
        That pic is from back when it was running a dizzy
          Thats Perfect John .Thank you
            It depends on the turbine housing size.
              I think i will go for middle size option but I will have to speak to Craig at Tdi Turbos first see what he will advise.
              just want to see the GT series in the engine bay to have a general ide what it looks like
              Shame that turbo hose between air box and turbo is nowhere near big enough to fit
                Roose will make you a hose with a larger outlet for the compressor housing. Depends if you want to keep to stock airbox or not really. Since you won’t need the MAF anymore you have a few more options
                  Oh good news then that Roose will make me a suitable hose .it will match rest of the plumbing
                  And I love the fact i can scrap the MAF.
                    ohh. so mototronic can work mafless?
                      No mate ,it can't .I'm going away from factory engine management system that's why I want have to worry about MAF anymore .
                        Doesn't prjmod make motronic mafless?
                          Yes
                            Mine is a .63ar
                            • #15
                              Originally posted by newsh View Post
                              Yes
