Garrett GTX3071R -Any photos available ?
  • piotr
    • Jul 2012
    • 1470
    • Home: Poland Current: England
    Hi .Just wondering if anyone has got photos to share of S2 engine bay with Garrett GTX3071r Gen2 bolted on to K24 flange manifold?
    Mine is a GT3071 on a Wagner RS2 Evo manifold.
    I believe the GTX is the same size but a more up to date compressor wheel design.
    It clears the chassis but you have to cut the leg off the airbox if you want to use a standard one.
        That pic is from back when it was running a dizzy
        • piotr
          • Jul 2012
          • 1470
          Thats Perfect John .Thank you
            It depends on the turbine housing size.
            • piotr
              • Jul 2012
              • 1470
              I think i will go for middle size option but I will have to speak to Craig at Tdi Turbos first see what he will advise.
              just want to see the GT series in the engine bay to have a general ide what it looks like
              Shame that turbo hose between air box and turbo is nowhere near big enough to fit
                Roose will make you a hose with a larger outlet for the compressor housing. Depends if you want to keep to stock airbox or not really. Since you won’t need the MAF anymore you have a few more options
                • piotr
                  • Jul 2012
                  • 1470
                  Oh good news then that Roose will make me a suitable hose .it will match rest of the plumbing
                  And I love the fact i can scrap the MAF.
                  • tango123
                    • May 2017
                    • 892
                    ohh. so mototronic can work mafless?
                    • piotr
                      • Jul 2012
                      • 1470
                      No mate ,it can't .I'm going away from factory engine management system that's why I want have to worry about MAF anymore .
                      • Antsa
                        • Nov 2016
                        • 612
                        Doesn't prjmod make motronic mafless?
                          Yes
                            Mine is a .63ar
                            • piotr
                              • Jul 2012
                              • 1470
                              Originally posted by newsh
                              Yes
