I noticed on the side of the waste gate the is a connection for a vacuum tube can anyone tell me where to connect the tube
RS2 Waste gate where do I connect the vacuum pipe?
There is a connection that's not used. Have you got a pic so we are talking about the right one?Nothelle S2 Avant
Urs6 plus project gone -
It's there to check if the diaphragm is split by fitting a vacuum pump to it and pulling a vacuum. If the vacuum falls you have a leak/split in the diaphragm.Comment
The larger one with the banjo on the WG lower chamber connects to the face of the turbo cold side via the N75. This controls the boost.Comment
The connector is a relic of the 10V Turbo engine, where boost was regulated via controlling the pressure of the upper wastegate chamber.
On 20V Turbos, the boost is regulated via controlling the pressure of the lower chamber.'95 Audi S2 Avant
'92 Audi Coupe T89 quattro 2.3EComment
