RS2 Waste gate where do I connect the vacuum pipe?
  • joss01
    • Apr 2019
    • 384
    I noticed on the side of the waste gate the is a connection for a vacuum tube can anyone tell me where to connect the tube
    • Dec 2017
    • 5992
    There is a connection that's not used. Have you got a pic so we are talking about the right one?
    • s0_big
      • Dec 2009
      • 685
      This one in my picture is not used:
      • joss01
        • Apr 2019
        • 384
        Thats the chap what does it connect to
        • steve briance
          • Aug 2014
          • 1455
          The two responses above both say its not used. I guess it might not connect to anything...
          • joss01
            • Apr 2019
            • 384
            Great I thought it was there to control the turbo over boosting the engine
            • Rikki Kitto
              • Feb 2010
              • 6276
              Not in use, something for doing checks with I think
              • joss01
                • Apr 2019
                • 384
                Great something else to cross of my list of "what is this for"
                • rustybullethole
                  • Aug 2013
                  • 531
                  It's there to check if the diaphragm is split by fitting a vacuum pump to it and pulling a vacuum. If the vacuum falls you have a leak/split in the diaphragm.
                    The larger one with the banjo on the WG lower chamber connects to the face of the turbo cold side via the N75. This controls the boost.
                      • joss01
                        • Apr 2019
                        • 384
                        great thanks for the image put my mind at rest
                        • shorty_94
                          • Dec 2015
                          • 60
                          The connector is a relic of the 10V Turbo engine, where boost was regulated via controlling the pressure of the upper wastegate chamber.
                          On 20V Turbos, the boost is regulated via controlling the pressure of the lower chamber.
                          '95 Audi S2 Avant
                          '92 Audi Coupe T89 quattro 2.3E
                          • joss01
                            • Apr 2019
                            • 384
                            I remember now had a WR UR and yes it was connected at the upper waste gate looking at the RS2 it has a tube coming out from the lower part of the wastegat controlling the pressure
