0,4 boost, first run with the car
  • Lopez90
    • Oct 2019
    • 119
    • Country: Norway
    Finally got to the point for testing my S2, so i bought a 1 day license for testing.
    I only get 0,4 bar boost.
    Tried with another N75 i found without luck.
    Tried disconnecting MFTS aswell.
    Got a VCDS to check for any fault, but couldnt connect, but ill make another post under electrical for that.
    Anything else i can check without diagnostic?
    Audi S2 Coupe
    Audi A6 C7
    VW T5
  • Lopez90
    • Oct 2019
    • 119
    • Country: Norway
    Got the VCDS to work, but right before i had to leave the garage. Been disconnecting the battery, but the only fault i got was:
    00533 Idle Speed Regulation
    10-00 - Adaption Limit Not Reached
    Does this have anything to do with me only having 0,4 boost?
    Audi S2 Coupe
    Audi A6 C7
    VW T5
    • Lopez90
      • Oct 2019
      • 119
      • Country: Norway
      Might have found something with the electrics to the N75. Anyone have diagram for it?
      Audi S2 Coupe
      Audi A6 C7
      VW T5
      • tekstil
        • Jun 2011
        • 104
        Should help you in right direction.
        • Lopez90
          • Oct 2019
          • 119
          • Country: Norway
          Tested N75 from vagcom and i can hear it click, so it does indeed have power, so thats not the problem afterall.
          Audi S2 Coupe
          Audi A6 C7
          VW T5
          • tekstil
            • Jun 2011
            • 104
            What kind of ECU do you have? Stock ECU on stock engine?
            What does this "first run with the car" mean? First run with the car after buying it, after rebuilding it?
            • Lopez90
              • Oct 2019
              • 119
              • Country: Norway
              Bought the car as a almost done project. Stock engine with stock turbo. Ecu with chip. Ecu has been tested on a 200 3b before i put it in mine.
              Audi S2 Coupe
              Audi A6 C7
              VW T5
              • tekstil
                • Jun 2011
                • 104
                You are probably missing some wire or vacuum/boost hose is disconnected somewhere. Look around intake manifold, wastegate and intake boot area, check associated hoses and their proper layout. Does the ECU have MAP hose/pipe connected to it? Hard to point out specifically without seeing car...
                • Lopez90
                  • Oct 2019
                  • 119
                  • Country: Norway
                  Yes, i put a Tee right before the ECU for the boost gauge. Shouldnt a bad connection make it vary with the boost? The car runs 0,4, no jerking or coughing at all. Constant 0,4 boost.
                  Audi S2 Coupe
                  Audi A6 C7
                  VW T5
                    Could be a broken or disconnected knock sensor
                    • Lopez90
                      • Oct 2019
                      • 119
                      • Country: Norway
                      Should it come up as a fault on vagcom?
                      Fault:
                      Audi S2 Coupe
                      Audi A6 C7
                      VW T5
                        Fault:
                        If disconnected it would , if faulty sometimes not.
                        Have you done a proper boost leak test yet?
                        • Lopez90
                          • Oct 2019
                          • 119
                          • Country: Norway
                          Just finished a boost leak test and found a minor leak, but doubt that would cause this. Gonna order new knock sensors and a ISV.
                          Audi S2 Coupe
                          Audi A6 C7
                          VW T5
                          • Lopez90
                            • Oct 2019
                            • 119
                            • Country: Norway
                            Tested voltaged on TPS today. 0,29v closed and 4,62 WOT. Does this eliminate out TPS failure?
                            This gallery has 2 photos.
                            Audi S2 Coupe
                            Audi A6 C7
                            VW T5
                            • tekstil
                              • Jun 2011
                              • 104
                              https://12v.org/urs/G69F60ThrottlePo...hTestSheet.pdf
