0,4 boost, first run with the car
  • Lopez90
    • Oct 2019
    • 119
    • Country: Norway
    #46
    Yes, the n75 is connected correctly (as the link says)
    Audi S2 Coupe
    Audi A6 C7
    VW T5
      You can do a final check on the N75. Remove it from the car, connect a short bit of hose to the leg of the T, connect an air line or just blow through it, the air should come out of the short arm of the T.
      Now trigger the valve with a battery, 12v is fine or a 9v PP3 radio battery will also do it. With the valve energised the air should come out of the long arm of the T and NOT out of the short arm.
      If the N75 is operating correctly, and we know it's ticking on the car so the wiring is ok, then the ECU is not demanding boost (it's in limp mode)
      Possibilities
      Pull codes again, see if you have an Adaptation fault. Could likely mean an air leak.
      It's possible the hose to the map sensor in the ECU is kinked, damaged or disconnected.
      There's a boost/vacuum leak you haven't found.
      The distributor timing is slightly out, on the 3B this has to be perfect. Check the Zero mark on the flywheel against the marks in the dizzy. The front pulley mark is not accurate. Put the car in gear and roll it forward onto the msrks to take up backlash.
      • Lopez90
        • Oct 2019
        • 119
        • Country: Norway
        #48
        OK thanks. Will check N75 again tonight. Got the vagcom here aswell tonight so i can pull out codes.
        About distributor timing i found this link if anybody else has issues and finds this thread: quattroworld.com Forums: UrS4/UrS6/S2/RS2
        Will post what i find out later on, thanks again mate
        Audi S2 Coupe
        Audi A6 C7
        VW T5
        • Lopez90
          • Oct 2019
          • 119
          • Country: Norway
          #49
          VCDS connected now. When i blow air in the leg i can only get air through the short arm. When N75 is activated i can blow air through the long arm BUT i can feel air coming in the short arm aswell. Both my N75 works the same when i tested.
          Audi S2 Coupe
          Audi A6 C7
          VW T5
          • Lopez90
            • Oct 2019
            • 119
            • Country: Norway
            #50
            Blowing in the leg and filming the short arm hose
            Audi S2 Coupe
            Audi A6 C7
            VW T5
              Hmm, I'm going to have to check my spare N75 now!
              • Lopez90
                • Oct 2019
                • 119
                • Country: Norway
                #52
                Would actully love it if yours are completly shut. If not i need to go further in the troubleshooting
                Audi S2 Coupe
                Audi A6 C7
                VW T5
                  Originally posted by Lopez90
                  https://youtube.com/shorts/YMTDOWTw9IA?feature=share
                  Yes, I have just tested 3 old ones here and they're all the same, in fact they leak a little in both directions.
                  So I guess that's normal, they're just not very good valves.
                    Sorry mate..
                      Just a quick check, get someone to sit in the car and push the accelerator pedal to the floor.
                      Check the throttle is actually going to WOT, ie no slack.
                      • Lopez90
                        • Oct 2019
                        • 119
                        • Country: Norway
                        #56
                        Will do. How do i actully see if its WOT? Can't i read it from vcds?
                        Cleard the errors and fired her up in the garage, didn't drive it but looks like i have 00516 closed throttle (idle) position switch
                        Audi S2 Coupe
                        Audi A6 C7
                        VW T5
                        • Lopez90
                          • Oct 2019
                          • 119
                          • Country: Norway
                          #57
                          Error code.
                          G28 failure due to engine not running i assume.
                          Audi S2 Coupe
                          Audi A6 C7
                          VW T5
                          • Lopez90
                            • Oct 2019
                            • 119
                            • Country: Norway
                            #58
                            Cant hear the f60 click either. Tried measuring between pin. 4 and 6 aswell (diagram attached) only have open circuit.
                            Audi S2 Coupe
                            Audi A6 C7
                            VW T5
                            • Lopez90
                              • Oct 2019
                              • 119
                              • Country: Norway
                              #59
                              Adjusted TPS and now it clicks - fault gone Went for a short ride and pulled 00533 - Idle Speed Regulation. 10-00 - Adaption Level Not Reached.
                              Followed this guide: quattroworld.com Forums: G69 / F60 Throttle valve position potentiometer /idle switch information
                              Across Pins 2 and 3 on the switch:
                              Throttle closed = 750 to 1300 ohms
                              As throttle is opened from closed to WOT = increase to 3600 ohms
                              If NO, replace sensor.
                              got only 3006ohm on WOT between Pin 2 and 3. could this be the cause why i wont get my boost?
                              Audi S2 Coupe
                              Audi A6 C7
                              VW T5
                              • tekstil
                                • Jun 2011
                                • 104
                                Measured mine an hour ago, it's AAN TPS (while doing so, discovered that my throttle cam end is broken ):
                                throttle closed: 940 ohm
                                WOT: 2480 ohm
                                Measured with some random cheapish multimeter and TPS was hot.
