vacuum hoses
  • topsparky
    • Oct 2005
    • 2014
    vacuum hoses
    any body know the diameter of the hoses needed
    i'm going to replace them all with samco silicon hoses
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    8. fmic fitted
  • iain1067
    • 984
    Take one off and measure it???
    • pastures16
      • 2058
      hows your gasket prob deano
      94 s2 avant
      aoc member 1116
        5mm ID bore is what is most commonly used.
        8mm ID bore for WGFV pipes
        • A80Avant
          • 10873
          • Country: Greece
          actually just did this a few hours ago.I bought myself the 4mm samco hose.It fits everything and actually in some cases the 3mm hose also was needed,but the 4mm also fitted fine.
          the wgfv i think uses 8mm hose.i didnt get that.
          • topsparky
            • Oct 2005
            • 2014
            with what if i had a set of calipers i would have
            i just wondered if anyone had btdt
            1. SHORT SHIFT KIT
            3. H & R SPRINGS
            4. BILSTEIN SHOXS
            8. fmic fitted
            • topsparky
              • Oct 2005
              • 2014
              have n't had time to check it really, but seeing as i've just finished my
              contract and have n't got another job yet i think i'll have the time now
              when i've got the time ,i have n't got the money
              and vice versa
              1. SHORT SHIFT KIT
              3. H & R SPRINGS
              4. BILSTEIN SHOXS
              8. fmic fitted
              • A80Avant
                • 10873
                • Country: Greece
                can someone verify that the WGFV hoses that go to the turbo cold side and the wastegate are indeed 8mm??
                • Jonas_R
                  • 3781
                  • Country: Denmark
                  It is and it should be a reinforced hose.
                  /Jonas R.
                  Sleeper S2 Avant +450
                  A6 Avant 2.7t Stage 3
                  Audi S2 Coupe RS2'ed
                    I used 4mm Samco for just about all the vac hoses, I might have used a lttle bit of 3mm somewhere I think.. 8mm reinforced for the WGFV.
                    Be very careful with the routing of the silicon vac hose, if it rubs on an edge it goes through in no time at all.
                    • A80Avant
                      • 10873
                      • Country: Greece
                      already had that problem but fortunatelly no loss of air there.OK
                      thanks for the answer
                      • A80Avant
                        • 10873
                        • Country: Greece
                        hey is the reinforced samco the one called superflex that they advertise on their web site?
                        • Jonas_R
                          • 3781
                          • Country: Denmark
                          Well i think that you can use the straight hose as well. It just that you should not get the vacuum hose in 8mm since this has a smaller wall size.
                          /Jonas R.
                          • A80Avant
                            • 10873
                            • Country: Greece
                            so i shouldnt buy the vacuum 8mm hose,which one then?i have tons on the bay but dont know which to order!!!
