cam belt position is looking odd
    • Dec 2017
    • 5992
    You have an aftermarket adjustable top sprocket. Maybe it sits further in?
    • Bowie69
      • Nov 2013
      • 2675
      You mean the exposed fibre/thread on parts of the edge of the belt?
      I think that's normal, just how they are manufactured.
      • Monkeymagic
        • Mar 2012
        • 3419
        What does it run like with engine running?, I've seen many belts run with slight "walk" back and forth as through the belt wasn't manufactured perfectly true, if that makes sense...
          • Dec 2017
          • 5992
          And the belt is directional. Look for the arrow.
          • S2_avant 19930325
            • Mar 2019
            • 648
            Exactly ,, then i know that is not a issue
            • S2_avant 19930325
              • Mar 2019
              • 648
              I turned over the belt manually with a wrench on the crank. Then it when it a bit , but i believe its different with engine running or with a wrench . I understand how you mean. The thing is that my belt was outside the cam sprocket. Like 2mm that can not be correct ,, or ?? Cant start it now, im doing maintence on the wiring and redoing the exhaust system from 3,5 to 3 inch.
              • S2_avant 19930325
                • Mar 2019
                • 648
                It lines up with the water pump and the tensioner so it is not further in i believe.
                • S2_avant 19930325
                  • Mar 2019
                  • 648
                  The arrows are correct
                    Have you got the “diamond coated washer” where it should be behind the bottom pulley?
                    • S2_avant 19930325
                      • Mar 2019
                      • 648
                      Have not yet takdn it a part. If its missing , should the belt not go closer to the block ?
                        I’m not sure, maybe if it’s further in at the bottom it makes it further out at the top? I have no evidence to back that up though! lol
                        • S2_avant 19930325
                          • Mar 2019
                          • 648
                          So , i got the parts. Water pump skf and bearing. And a gates cam belt. Now i got these 2 tools but the dont fit. Will make my own , but i still dont under stand how to lock the tool ,, se my drawing. The tool for ABY looks similar. But a bit modified. I saw ultra performance have them for aby with fluid damper.
                          Its a 2084 and it seems that they dont work for a fluid damper.
                          • Bowie69
                            • Nov 2013
                            • 2675
                            If you have a snub mount spare, you can bolt it to the block then your tool works perfectly.
                            • S2_avant 19930325
                              • Mar 2019
                              • 648
                              What do you mean with snub mount ? The tool 2084 looking tool does not reach for enough in to lock it properly. I can make my tools i need. But thanks anyway. Is that aluminium insex that is for the tensioner strong enough ?
                              • Bowie69
                                • Nov 2013
                                • 2675
                                For earlier engines, inc 7A, 3B the snub mount is different (which is why your tool doesn't fit), if you have an earlier snub mount then you can bolt it on to your block and your tool will then work, it is much longer than the ABY snub.
