Electrics aren't really my thing, but have you made sure your engine is earthed to the chassis correctly? A bad earth could explain some of this weirdness.
No relay on the starter, you should see between 12.5 and 13 volts while trying to crank it.
1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.
I think you said before that you were able to start it using a screwdriver in the ignition switch. If this is the case, you problem still lies with the ignition barrel.
Yes, not sure why all the discussion about alternators and stuff -the switch works, last I read, your problem is the missing piece of die cast metal that has broken off the back of the barrel, and that turns the switch.
Battery light on is normal with no engine running, read your user manual
No .. i could not start it before ,,, i put a wire direct to starter and a button. But the problem is solved .. i amlost dont want to say it.... but the T1 and G8 cables were switched ,, thats why the oil temp was giving max temp on just ignition. Still the ignition barrel was broken so i had to replace it any way ... so now to go on to look why the oil lamp is flashing and why the battery lamp is on always.
The big oil sensor on left side of the engine with connections. I measured it .. OHM.. i have 10,2 .. could somebody measure it would be helpful. ?
On my leftside the position light does not work and every time i change the 5 amp fuse .. it burns of a soon i put i in. If i disconnect the connector to the lamp .. the fuse still goes off directly. So i have shortcircuit some where ,, but can i check it from the connector on the left light ? its a 3 pin. How is the best way to check a short circuit ?
I do have a Sealy short finder. It's like a probe and follows a wire. Good to use with easy access but in your circumstances I don't think it will be much good. Just carefully trace the wire back looking for damage. It's more likely someone has incorrectly connected something where it shouldn't be in your circumstances. The other issues are probably the same.
i have a wire finder so i can track the wire but difficult ,, when i measured 2 of the pins .. i heard the sound of the motor on the other headlight. So 2 pins must be motor up and down and third pin must be 12 v .. correct ? But it can be something before the power goes threw the fuse .. under the dashboard in the wires .... hmm i found 2 videos how the check the 2 oil senders on the left side of engine. So that will be tomorrow. And then im left with battery lamp. Have to look if i can find something in service manual or something.
Well .. still problems .. it started again to bug with the oil lamp,, hmmm .. its must be the alternator ,, it does not do what it should with the dash lamp , it gives power constantly on little blue cable on the alternator. What aslernators are good for audi s2 that fits original brackets ? ,, any OEM numbers .. i dont have to have original ,, just want it to work. Or i have some issues with somekind of grounding issue on some cable for something. It did work yesterday when i started it ,, no oil lamp ,, today issue with oil lamp. Now im starting get a bit angry ... hmmm
