Which diverter valve do you have?
  • terrybullwon
    • Mar 2006
    • 8782
    Originally posted by AndersS2
    I run the Turbosmart Plumb Back DV on mine! Works very well and look stealthy
    EDIT: it's adjustable too so you can get the chatter if you want too
    Sounds good Anders,
    Does it losen off the spring when you adjust it? if so.... do you get an noticeable side effects? less/more lag?
    I run the forge and with the open cone you get a nice bit of wg chatter, see the video in my sig, just need to turn it up a touch was very windy!
    Cheers James
    Chef
    • AndersS2
      • 1364
      • Home: Norway
      Originally posted by terrybullwon
      Sounds good Anders,
      Yes James,
      it does impact on how you adjust it.
      I got told to adjust it rather soft than hard to get it to perform optimum. I tried to adjust it a little and feel the diffrence, but on my old "ketchup setup" it was imossible to notice, and on the current setup, I feel a little earlier boost on WOT and easier to boost from lower revs.
      On half throttle it has little to non effect i think.
      Anders - S2 Avant Clubsport - 8pots or die!
      • Mark Halligan
        • 2001
        50mm Tial BOV
        Mark - Modded
        • Bibby
          • Aug 2004
          • 1043
          Milltek HX2
          acidtrax
          • Matt_D
            • Dec 2004
            • 515
            Forge 007 for me, i wanted one thats servicable and more reliable than the plastic bosch valve.
            Can i add although i have an s2 airbox with K&N panel filter the Forge is not silent as some people think.
            I can hear it dumping obviously not as loud as a VTA valve but just something to think about
            '95 ABY Avant - Sold
            '98 B5 S4 -MRC400+ = 464ps 741nm
            • A80Avant
              • 10873
              • Country: Greece
              #21
              actually i voted wrongly.I have the forge 006DV for me which is bigger than the 007.Forge suggestion to use that one instead of the 007 on the RS2
              • rs2315
                • Jun 2006
                • 867
                Just more info
                rs2315.
                • S-Express
                  • Nov 2006
                  • 1133
                  #23
                  So if you change the standard dv, is there any setting up that's needed on an aftermarket one?
                  I see the Forge 007 comes with 4 springs to match your boost level - what's all this about?
                  (sorry - I know a fair bit about engines but the S2 is my first turbocharged car - AND I LOVE IT !!!)
                  • CliveH
                    • Jun 2005
                    • 1319
                    #24
                    The Forge one comes with a "standard" spring.
                    You can then buy a "tuning kit", which comprises 4 different coloured springs of varying strength and some washers, to alter the characteristics of the DV.
                    If you use the standard setup, it should just be "plug and play"...
                    Past: S2 ABY coupe RS2 spec with lots of mods, S4 B5 saloon, RS6 C5 saloon, S8 D2 FL, RS4 B7 saloon, S4 B6 avant
                    Present: S4 B8 avant, MRC Stage 2
                    • S-Express
                      • Nov 2006
                      • 1133
                      #25
                      great, thanks - use standard spring even with a home fry??
                      • CliveH
                        • Jun 2005
                        • 1319
                        #26
                        hmmm...not so sure about that - as I'm usually in the "plug and pray" camp, I would wait until someone who knows what they're talking about comes along
                        • S-Express
                          • Nov 2006
                          • 1133
                          #27
                          Ah, now I've searched the forum I see I should use a green or yellow spring !
                          • CliveH
                            • Jun 2005
                            • 1319
                            #28
                            You'll need the tuning kit too then...
                              S3 one cos Doug said it was fine for a standard car and at £15, I quite quickly agreed with him! No problems with it so far.
                                The thing with the S3 one you'll end up replacing it, with an alloy piston one you can service them. Classic case of save now pay later or pay now save later.
                                Pays your money takes your choice really.
