What the F*** :(
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    Originally posted by Azman
    Actually they do look pretty grotty. What did you use to clean them?
    Az
    Contact cleaner spray with protective oil from your favourite electronics shop . First clean with some soft cloth (no sandpaper or screwdriver there!), spray. Connect/disconnect several times, clean again, spray, leave and forget .
    My human carrier was standing for 1.5 years before I've bought it, so there was entire swarm of electrical gremlins under the bonnet (playing tricks with the wiring ). After such procedure there was no need to repeat such procedure for anything under bonnet. With an exception of electric window switches in the door handle.
    I use this one:
    Sau
      I had this too, drove me crazy.. The very best contact cleaner for all your plugs and sockets is Caig DeOxit, fantastic, even makes your headlights brighter You can find it on ebay in a spray can, I also have a marker type pen thing with it in
      • Azman
        • 3205
        Right cleaned all the contacts, inc hall sender, tps and MAF. Cleaned the MAF completely and refitted everything once dry......
        AND it's still happening.
        hopefully reset the ecu by pulling all the fuses at the front of the fusebox and even diconected the battery for 30mins.....
        Nip zip nada. Had the dizzy cap off checked and cleaned that. marks are bang on center of the prongs so that is all good......
        ANy clues.....
        Is it the MAF???? How can you test it.
        BTW I don't have vagcom and it is not connected in the car (been there tried that couldn't get a connection....)
        Az
        Dark Grey Avant
        RS2 FARB
        Alloy Subframe Bushes
        • LHD_Kid
          • May 2006
          • 3697
          long shot I know, but check the wiring and condition of the connections toi the ECU coolant temp sensor in the rear of the block, the same side as the airbox, might be worth a quick look....
          HTH
          Chris
          • Azman
            • 3205
            It has got a newish loom in that has been fully repaired and continuity tested for a vey long while to ensure all is correct. So can't see it being the wiring.....
            Az
            Good shot though will still take a look
            Dark Grey Avant
            RS2 FARB
            • tgriff
              • May 2007
              • 41
              give me a shout if u want to try my maf az.
              • Azman
                • 3205
                Cheers for that tgriff more questions than answers though so get your brains ticking lads and lasses.....
                Right...
                Swapped MAf over with a new one (ala tgriff) and the car seemed to be more hesitant (I did take the neg off teh battery for 10 mins while I was swapping over to reset the ecu).
                Idle was more stable and witht the ISV plugged in it was between 500 and 1K rpm instead of 500 to 1500RPM....
                On a quick drive teh car popped fuel in teh exhaust alot more with a bit of throttle and was alot more hesitant only hitting about 5psi of boost, not a boost leak as it would not be this variable would it... Pipes are all samco and fixed tight with decent clamps.
                Putting the new MAF on has thrown up teh question of reseting the throttle body to sort teh idle out but still no clue on the boost......
                Thoughts please girls and boys...
                Az
                Dark Grey Avant
                RS2 FARB
                • Azman
                  • 3205
                  No thoughts then guys????
                  Dark Grey Avant
                  RS2 FARB
                  • QuattroFever
                    • May 2006
                    • 1360
                    Had the same prob. on two S2's. troubled me for weeks. I can't explain why. Airbox on, there. cone on. gone. strange.
                    give the jubilee on the discharge side of compressor, on the outlet a little nip. it worked for me.
                    you can usually see it from underneath. if its been playing up you might see black spatter up the side of the outlet.
                    Volcano ABY coupe
                    Ant
                    • Azman
                      • 3205
                      All those have really good hose clamps on (notice clamps not juby clips) as I want ed to make sure that it was all very tight so I didn't have to take it apart again, also I don't think I will see much blowing from there due to having a catch tank to remove all that fromt eh flow..... Will have a nip under there wil a spanner though just to make sure nothing has moved or come loose.......
                      REally bugging me, could it be to do witht eh throttle pot????
                      Az
                      Dark Grey Avant
                      RS2 FARB
                      • Azman
                        • 3205
                        Or could it be the 4 pin temp sender as per S2central's thread???? The water temp guage in the car does what it likes and is on for a bit then off...... Could it be taht little beauty??
                        Dark Grey Avant
                        RS2 FARB
                        • Ski
                          • 2591
                          #27
                          bit of an agressive thread title probably putting people off this thread fella...
                          you could try soapy water onto pipes to see if any bubbles start blowing. Just my 2 cents.
                          ABY Coupe
                          • Azman
                            • 3205
                            Point taken can any of the mods change the title please..... To something like , Help to find out what is wrong.
                            |Cheers sorry, you can guess the mood I was in when I wrote it can't you...
                            Good point witht the soapy watre ski.
                            Will give it a go.
                            Az
                            Dark Grey Avant
                            RS2 FARB
                            • LHD_Kid
                              • May 2006
                              • 3697
                              #29
                              The MFTS does do some strange stuff indeed,.... I changed mine and sorted some running problems, its around 40 quid or so, and if its old, and the temo gauge is playing around, it mUST be worth changing it to see if it cures the running and temp display problems...
                              Sorry can't suggest any more, been thini\king hard though....
                              Are you sure there are no leaks in the vacuum pipes?
                              HTH
                              Chris
                              • QuattroFever
                                • May 2006
                                • 1360
                                aaah, well said. worth a look at that. I had a boost leak under my rear seat. The non return valve for the diff. lock was lettin by.
                                Do you have any trouble with the diff. lock engaging when on boost?
                                if not as mentioned above check the hoses anyway.
                                Volcano ABY coupe
                                Ant
