I'm not dissing this company here on the thread - just giving my opinion based on the knowledge I have built up.
Purely mechanical boost control is fine up to a point but its an 'old school' method from the 70's and 80's.
The advantage of the WGFV system is two-fold. Firstly it allows the ECU and its software to define the boost profile over a wide range of throttle and load conditions and no mechanical tweaks are required to alter the boost profile - just software. The 2nd benefit is that the ECU can choose to reduce boost (gently or firmly) in the event that it detects fault conditions which could be harmful to the engine, such as prolonged knock with the use of poor fuel or excessive temperatures etc etc
If you remove the WGFV then you are removing some of the ECUs ability to failsafe when faults are detected. You will be reliant on the ECUs ability to limit fuelling and ignition in these scenarios which is something useful, but not as good as being able to falback to a safe level of mechanical boost.
In stock trim the mechanical boost ceiling is 0.4bar on the S2 - which you cannot achieve with a thumping great aftermarket WG spring that sets (say) 1.4bar - you could be mashing all that boosted air into the engine regardless of any fault detected by the ECU.
Paul
Paul
