Well seeing as all my front suspension is off the car waiting parts for arrival in the new year, I thought I'd get stuck into Plan A which was to renew the timing belt, coolant pump and all the auxiliary belts. I did the thermostat and link hoses a couple of years ago so they are grand.
In about 90 minutes I managed to get about this far -
1 - Undertray off (and worryingly found what appears to be a leak at the oil cooler pending more investigation)
2 - Front bumper off (all lights out first) and front panel removed
3 - Coolant drained & auxrad removed
4 - Intercooler and X-member removed
I've left the next items for removal soaking in some WD40 - planning on removing the aircon compressor without opening the system and the brackets for the pipes look mighty crusty.
Definitely got some oil leakage down there which has peed me off - this car is going to empty my wallet rather more badly than I had hoped, but it is the 1st amount of serious work that I've had to do in over 6 yrs of ownership so I can't complain that much.
Photos to follow - trying to keep notes here to help others and remind me when I come to creating a more detailed 'how to' someday.
Paul
Paul
