I'm not good @ physics, however I guess, that 450Nm is 450N at 1m radius, so you need approx 45kg of force at 1m length bar. Or your weight at something around half of that (both feet up in the air)
I may be wrong
. But I torque CV nuts (typ85) with one of my legs on 1m bar (~35kg), and they are tightened pretty well so far (tested successfully more than 20 times).
And about "calibration" - you can use bathroom scales, to calibrate your force (actually did that for brake pedal force measurement
Sau
.I may be wrong
. But I torque CV nuts (typ85) with one of my legs on 1m bar (~35kg), and they are tightened pretty well so far (tested successfully more than 20 times).And about "calibration" - you can use bathroom scales, to calibrate your force (actually did that for brake pedal force measurement
).Sau
.I have broken the tool from audi vag 3256. Then i made my own up with a long handle and a large socket with a slot cut out .and used the ground to pull on. broke my socket then whent and got a impact set then the wrench handle broke. so got a (for life set) that broke with a 1.5 mrt bar on it .Ive put heat onit , left it over night with goo. I was jumping up and down on it .im not a small chap(f95kg)what is the bolt made from, I can not move this thing at all
,can i borrow these please or has anyone got any good ideas.i will be willing to tavel a few miles to say the least to get this sorted.
