ABY Timing Belt Renewal
This is a sticky topic.
  • terrybullwon
    • Mar 2006
    • 8782
    Here you go
    Chef
    • TimE-J
      • Jul 2009
      • 1292
      That looks like a good piece of kit, that put a few more ideas on the drawing board! Cheers mate.
      96 S2 aby Coupe. Rebuild Project
      96 mk3 golf tdi daily.
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        #78
        I know this is the ABY timing belt but I just checked for the ADU one and it now retails at 97€ from audi in Germany!!!! Yikes!!!
        • Monkeymagic
          • Mar 2012
          • 3419
          That counter hold is for a t4 5 cylinder. Its what i intend to use when i tackle mine.
          • John.
            • 2615
            Regards the 450Nm = 200Nm + 180 degrees.
            I've just done the belt, pump and idler on my 7A engined coupe.........and here's a picture I've taken of the pulley.
            I marked the head of the bolt and then torqued it to 100Nm, then marked the pulley.
            I then torqued it to 200Nm......and marked the pulley.(The torque wrench used was calibrated about 3 months ago.)
            Observing the difference between the 2 marks I then marked the pulley with another 2 paint "dabs".....to give an idea of 300Nm and 400Nm.
            It was at this point that I thought 180 deg from the 200Nm mark might be about 1000Nm?!
            .....anyway using a 3/4 drive socket,t-bar and small length of scaffold tube, I "nipped" it up a bit and the pic above shows where it finished up. To me it felt f***ing tight.
            Incidentally when I slackened the bolt at the start I used a 1/2 inch bar and it broke free 1st try, it had thread-lock on it and hadn't been touched since the belt was fitted 5 years(15k miles) ago. I have the receipt from the garage that done the job-the original bolt was re-used.
            Now, I'm thinking maybe the pitch of the thread on the bolt is different from that of the S2 engine??........but I understand that the crank is the same??(yes/no)......so surely the pulley and bolt are the same?
            .......anyone?
            • Jonas_R
              • 3780
              • Country: Denmark
              #81
              200 + 180degrees is more accurate then 450 Nm. Then last 250 Nm can vary alot depending on friction etc. in the bolt thread, where as 180degrees will always be the same.
              Sleeper S2 Avant +450
              A6 Avant 2.7t Stage 3
              Audi S2 Coupe RS2'ed
              • irishs2
                • Apr 2009
                • 2455
                John , is that a new bolt or the old one?
                Eric
                95 S2 Avant under rebuild.
                  That's not a new bolt.
                  • John.
                    • 2615
                    Original bolt.
                    Happy with it but plays on yer mind a bit!!
                    • irishs2
                      • Apr 2009
                      • 2455
                      Nothing major, I was just thinking about the torque comment, and Jonas's comment on friction.
                      New bolt vs old bolt surface ,rust and no rust etc.
                      But yea I would always use a new one
                      Eric
                      • John.
                        • 2615
                        Fair enough.
