Turbo upgrades and chipping.
  • SteveH
    • 4460
    Mark...Why not go the whole hog and get some custom cams ground
    91 Modded 3B
    14 A6 Avant Black Edition
    • Mark Halligan
      • 2001
      Steve, I already have the 7A's, and to honest I cant afford custom profile cams at the moment.
      Mark.
      Mark - Modded
      • Doug_RS2
        • 3847
        #33
        I'll see if I can notice a difference in the 7A and ABY exhaust cams I have lying in the garage.
          #34
          For the record, a generic chip upgrade (aka 'homefry') on the ABY gives 280bhp peak power and 430Nm peak torque. The generic 3B upgrade is a little less at 270bhp and 410Nm, but the lower weight of the 3B evens them out on paper.
          I'm 99% sure that the cam pulley on the RS2 is different than the S2 - didn't SAL find this to be the case on his conversion ?
          7A and RS2 cams work fine in the 3B or ABY engines, as long as you don't use the RS2 pulley. Am fairly sure the RS2 timing belt has different teeth spacing, and therefore water pump as well - maybe someone with ETKA can confirm or deny please !!!
          Paul
          • sal_s2
            • 1287
            The pulleys look identical to me. Both have two marks on the back,
            • sal_s2
              • 1287
              and the same amount of teeth
              • Mark Halligan
                • 2001
                Thanks Sal,
                I cant clearly see the timing mark on the wheel to the right, but as you say they do look the same, including the tooth spacing.
                Mark.
                Mark - Modded
                • Mark Halligan
                  • 2001
                  Thats funny I just noticed on the pics Sal posted, that there is no 'cast in' Woodruff key, but a machined slot. I seem to remember someone posting that that woodruff is cast as part of the pulley :confused: .
                  Mark.
                  Mark - Modded
                  • APNess
                    • 479
                    they are - those two are knackered with the keys having been sheared off :S
                    PJ
                    'The Bacofoil Express'...
                    No more.
                    Leon TDI 150 run in now.
                    Very slow.
                    Needs a chip.
                    • Doug_RS2
                      • 3847
                      #40
                      Sal - can you take a picture of the rear of the pulleys - like my one I took - so I can see if they are the same as mine?
                      • dan_b
                        • Sep 2003
                        • 3670
                        #41
                        Paul - does the generic homefry automatically cope with, say, replacing the cams with 7As, or should it be re-fried for that specific motor in order to work better with the new cams? Do you think the MTMed ECU would work any different?
                        How many extra horses would a 3B that is already stage1 fried gain with the 7As do you think?
                        • sal_s2
                          • 1287
                          As Paul said both keys have sheared off.
                          Pic of rs2 pulley
                          • sal_s2
                            • 1287
                            s2 pulley
                            • martinjs
                              • 3205
                              woops...didnt realise, my picture was from the other side
                              i'll get me coat.
                              • sal_s2
                                • 1287
                                ops: s2 pulley
