How long to remove and fit an S2 engine
I think it depends how much of that plastic crap there is under the bonnet. As I've removed mine I can have just about all of the ancillaries out in an hour or two. If you have to work around all the plastic then indeed 10 hours is a conservative estimate. -
Jamo,
I've done it twice and I'd say 10 hours minimum but a lot depends on your facilities, is the car on a hoist or ramps etc. and then there's just no knowing how long some of Audi's design features such as one nicely concealed turbo flange bolt with a specially sized 16mm nut on a m10 stud (which you'd expect to have a 17mm nut as the other 2 are) just so they can squeeze it in will take to undo.
Like lots of things in life, it depends how good your tools are.............
JohnLeave a comment:
For those that have done it before, how long does it realistically take to remove and refit an engine into an S2?Tags: None
